View Poll Results: Faster, Slower or Same as the M3 GTS ? | |||
Faster | 52 | 78.79% | |
Slower | 7 | 10.61% | |
Same | 7 | 10.61% | |
Voters: 66. You may not vote on this poll |
03-28-2014, 03:53 PM | #1 |
8
Rep 94
Potential of the New M4, Faster or Slower then the M3 GTS ?
Since there is not much going on and no new information being released on the M4 any time soon. What's your speculation on the the New M4, Faster, Slower or Same as the M3 GTS.
Specs on the M3 GTS 450 BHP (4.4l V8) 1490 kg / 3278 lbs (DIN standard) 6 / 4 piston brake system 6 point harness 255 35 19 F 285 30 19 R Rollbar behind the front seats ( only 2 seats ) Front splitter and Spoiler ( adjustable ) Performance Nordschleife BMW M3 GTS 7:48.00 BMW M3 E92 8:05 Max speed 305 kph (189.1 mph) 0 - 50 kph 1.8 s 0 - 100 kph 4.3 s 0 - 130 kph 6.3 s 0 - 200 kph 13.1 s 0 - 100 mph 8.9 s 1/4 mile 12.3 s Engine Power 331 kw (444 bhp / 450 ps) @ 8300 rpm Torque 440 Nm (326 lb-ft) @ 3750 rpm Last edited by Flying Brick; 03-28-2014 at 04:20 PM.. |
03-28-2014, 04:07 PM | #3 | |
8
Rep 94
Also it will be very easy to tune the m4. Just chipping it would give u easily 80 hp. |
03-28-2014, 04:11 PM | #4 |
1712
Rep 5,108
The new M4 is at least 10s faster round the Nurburgring than the E92 M3.
How much faster was the GTS? (a time set on similar tires obviously) If you compare those times you should get a good indication on relative performance. |
03-28-2014, 04:15 PM | #5 |
8
Rep 94
03-28-2014, 04:22 PM | #6 |
21105
Rep 20,741
Drives: 2021 911 turbo
My guess is that the M4 will be faster with the same tires as the GTS.
For this, I am assuming that the S55 is underrated and that it actually produces 440-450hp |
03-28-2014, 04:26 PM | #7 | |
1712
Rep 5,108
swamp2 has done simulations and I believe that he expects the M4 to be something like 15-20s faster than the E92 M3 around the Ring. BMW has claimed "at least 10s"... |
03-28-2014, 04:28 PM | #8 |
21105
Rep 20,741
As you stated yourself, the tires are a huge variable
03-29-2014, 03:30 AM | #11 |
8
Rep 94
03-29-2014, 03:56 PM | #12 | |
46
Rep 164
My fist post was meant to be taken as a bit of humor, but since I refuse to use little smiley faces in my posts I could see how my sarcasm would not translate well in the written form.. My bad... Last edited by ZGM3; 03-29-2014 at 04:01 PM.. |
03-29-2014, 05:36 PM | #14 |
3771
Rep 1,665
Drives: M2 CS | M135i
I had the chance to be passenger in my friend's GTS (around the Ring) and to drive it (carefully) on public roads. All I want to say is that it doesn't matter which one is faster because the M4/M3 will never be as track focused than a GTS. It's just amazing how this car is different than a regular M3. When I drove back my E92 zcp I had the feeling I was driving a Prius...
2020 M2 CS DCT
2021 M135i xDrive ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe |
03-29-2014, 05:37 PM | #15 |
351
Rep 1,749
Given the M4 will likely be equipped with Michelin Pilot Super Sports versus the GTS's Pirelli Corsa's I think it will still be close time to the GTS. given a set of Pilot Sport Cup II's I think its gonna be surprisingly fast. I will wager a 7:39 lap is possible on PSC-2. 7:49 on PSS.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
03-29-2014, 09:01 PM | #16 | ||
552
Rep 2,633
03-29-2014, 09:17 PM | #17 | |
11820
Rep 15,400
03-29-2014, 10:08 PM | #18 | |
8
Rep 94
They have a flash for 435i which give you 100 hp at the crank. So 80 to 100hp is something we can expect for the M4/M3. |
03-29-2014, 10:24 PM | #19 | |
8
Rep 94
"The suspension is a familiar strut-type front end with a multi-link rear. BMW says it took advantage of its DTM drivers Bruno Spengler and Timo Glock in the development of the 2015 M3 and M4 suspension settings, including extensive testing at the Nürburgring-Nordschleife. New aluminum suspension elements reduce unsprung weight." Last edited by Flying Brick; 03-29-2014 at 11:33 PM.. |
03-29-2014, 10:49 PM | #20 |
17
Rep 239
Mmm
03-30-2014, 02:53 AM | #21 |
5457
Rep 7,037
I think the GTS will eat the M4 on the track unless the driver is a pro. But I assume a future special version M4 will be wickedly fast and spank all prior M3s.
03-30-2014, 08:24 AM | #22 | ||
1054
Rep 1,459
