Coolant Leak From i dont know where
03-28-2014, 09:07 AM | #1 |
48
Rep 500
Okay guys this morning i started my car and boom coolant warning came on lucky i had BMW coolant in my trunk so i filled it up, drop my dad off at the bus stop 4 blocks down and start heading to my gf house, after another 5 blocks boom coolant warning come on so i pull over at the gas station and open the hood and a bit of steam and coolant splashed everywhere. I believe its coming from underneath where the air filter plastic that sits on top near the kidney grills. I looked underneath and it was like a puddle and it was just going downward. Is it a hose issue, radiant issue? FYI i did get an oil change once at a local qucik oil change shop and they added some other type of coolant, that's why its green, i was going to get it flushed but they wanted $200 for something so simple, so i was going to do it in a week or so.
JB4 G5 ISO| DCI | BMS CF | OEM M-TECH F&R BUMPERS | AMUSE TRUNK |M6 RIMS | My Build http://www.e90post.com/forums/showth...1#post16458808 Previous: 2012 g37xs coupe |
03-31-2014, 09:23 AM | #2 |
295
Rep 2,202
Could be many things in there. There's the over flow hose that runs along the top of the radiator. There's the radiator itself. And the many other houses in there. It's hard to tell from just the pictures because everything is all hidden.
I would have the system checked like right now without driving it.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
03-31-2014, 10:36 AM | #3 |
181
Rep 1,681
Check the hose that runs under your air intake (under the part that connects to the snorkel). Lots of guys seem to break that one, it's plastic and gets brittle.
04-01-2014, 11:11 AM | #5 | |
48
Rep 500
04-01-2014, 11:13 AM | #6 |
48
Rep 500
I believe it was the one your talking about, it connects to the actual coolant fill up tank does under the vent ducts and connects to radiator, I did replace it and now smoke is coming out my radiator when the car is warmed up. it doesn't smell sweet it just smells like steam.
04-01-2014, 12:18 PM | #7 | ||
295
Rep 2,202
04-01-2014, 12:27 PM | #8 |
48
Rep 500
I haven't, and my coolant is greenish now, but BMW wants $200 for this, I tried doing it my self and I also took it to my friends shop but he told me it needs to be vacuumed or something like that. have u flushed it your self?
04-01-2014, 12:34 PM | #9 | |
295
Rep 2,202
04-01-2014, 12:41 PM | #10 | |
48
Rep 500
Only when venting! Note: Do not open the coolant expansion tank cap during the venting procedure. 1. Connect battery charger. 2. Switch on ignition. 3. Set heater to maximum temperature and turn fan down to lowest speed. 4. Press accelerator pedal for 10 seconds to floor. Engine must not be started. 5. The venting procedure is started when the accelerator pedal is pressed and takes approx. 12 minutes.(Electric coolant pump was activated and shuts down automatically after approx. 12 minutes). 6. Then top up fill level in coolant expansion tank with 100 ml above max (see illustration). 7. Check cooling system for leaks. 8. If venting has to be carried out again (e.g. if cooling system is leaking), allow DME to fall completely (leave ignition key removed for approx. 3 minutes), then repeat from Point 3. is this the procedure? and I can do the work if I have a decent DIY I think I can manage it.
04-01-2014, 02:24 PM | #11 | ||
295
Rep 2,202
04-02-2014, 12:24 PM | #12 |
48
Rep 500
Thanks, i did do it yesterday and it went well, no air in the pockets.
