Ticking and New Cylinder Head Count
11-17-2007, 10:30 PM | #1 |
8
Rep 115
Just trying to get an idea of the number of owners who have had the cylinder head replaced because of the ticking, and have you had any problems since.
11-05-2008, 10:40 PM | #4 |
20
Rep 450
i had the ticking noise too. The dealer said it was because the car had not been moved in a while. They changed the cylinder head. Now i had it for about 2k miles. Noise gone.
11-05-2008, 11:28 PM | #7 |
181
Rep 4,038
335 is a diff head tho.
i have it sometimes when i start the car sometimes right when im getting gout i hear it. at work i got into a 325 and holy crap it was bad and smoking like crazy after about 15 min of driving it started to go away. |
11-19-2008, 07:19 PM | #10 |
Drives Smart
54
Rep 2,393
My car has loud ticking, but I think nothing of it....thought it was valve lifters or something
along those lines...I have a pretty rough idle for an I-6 car 2. Does not change rpm's at all, but just car has 2 much vibration from her (the engine).
08 BMW ///M5 Space Gray/Black 6 speed Engine: RPi GTS exhaust, RPi Scoops, Carbon Filter Delete Exterior: Glossy Black Kidneys, LUX V3, OEM LED License Plate light, Bruce License Plate Adapter |
01-14-2009, 04:47 AM | #11 |
57
Rep 1,035
can the cylinder head ticking noise conflict with rough idles? i have the ticking noise and rough idles at times (idles like i have a vacuum leak). car doesnt gas at times when in gear. can this be the problem of the cylinder head?
this problem is stressing me out. please help |
01-28-2009, 12:37 PM | #12 |
Rep 3
2007 328i
I have the ticking, and it was noticed in the shop on my first major service last week at 15k mi. The service manager took it back in this week...said they would do the bleed but it only works in 10-15% of cases he said. It didn't work and they are ordering new cylinder head with the different oil drainage system that is the cause of the mess, causing oil starvation up on top at the valves, and which he said is costing BMW a fortune in replaced cylinder heads.
The cylinder heads are on back order with at least 3 week delay. |
01-29-2009, 12:45 PM | #14 |
8
Rep 138
My car ticks now and then... when cold or if driven with very low revs for long time. They told me at bmw service to keep the revs at 2000rpm untill it goes away. If i do this it will go away, or if i drive the car and rev it up a couple of times. Wonder if my head should be changed. Do you think my cams and lifters will wear out because of this?
Bmw 325i -06 "Slush o' matic"
20" Hartge classics with Falken 245/30 and 285/25*Eisenmann race 2x76mm*K&N Euro cone filter*H&R Cupkit race*Oem Front and Rear spoiler* Xenon led rings*Blacklines* |
01-30-2009, 01:14 AM | #15 |
Slaveaholic
17
Rep 707
had my cylinder head replaced also......after taking it to bmw about 3 times and them saying the infamous "cannot replicate problem". idiots....
got mine replaced March 08. |
01-31-2009, 02:45 PM | #16 | |
57
Rep 1,035
my service advisor seems to not care and doesnt do much to fix the problem |
01-31-2009, 03:27 PM | #17 |
202
Rep 2,740
Does anyone have the service receipt or invoice after replacing their cylinder head because of the ticking noise?
My dealer says it is normal for the BMW to have ticking noises… |
02-04-2009, 09:51 PM | #18 |
57
Rep 1,035
same here!
02-09-2009, 07:50 PM | #19 |
Rep 233
My SA told me that BMW has rescinded the method of cylinder replacement to fix the problem. But I wouldn't take his word for it, I'm going to contact BMW corporate and see what they have to say.
02-13-2009, 11:34 AM | #21 |
Mr. Monaco
155
Rep 4,197
yeh mine ticks too..and I dont like it. Servica Advisor didn't even attempt to help. Looks like a contact to BMWNA is in the works
03-05-2009, 11:30 AM | #22 |
Rep 3
3-Series Ticking Sounds
My cylinder head has now been replaced and the car's running fine with no ticking noise. The New Mexico dealer's service advisor said he has had more than 20 of them done alone...not counting the guys down the hall. So some of you guys' dealers have some integrity problems sounds like.
My invoice dated 2/25/09 states this: "Customer states there is ticking noise on startup SOPS IN Replaced cylinder head as per Puma Case #21862855 on R.O. 136942." All listed under warranty and no charge. Hope this helps. Heck...its warranty work...you'd think the dealers would be all over this. |
