My Dyno results
03-26-2014, 09:00 AM | #2 |
229
Rep 3,489
Drives: Montego Blue 335d
dixy great run but YES you lost somewhat around 20 hp , btw did you get the torque numbers if not call me and i will send you pics via whastapp so you can see where to get the correct readings ok
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
03-26-2014, 11:26 PM | #5 | |
88
Rep 1,152
The guy placed tape on one of the belts and used an optical tool to register the RPM. the tape just flew off the belt. No RPM, no torque. |
03-26-2014, 11:27 PM | #6 |
88
Rep 1,152
03-26-2014, 11:34 PM | #7 |
213
Rep 2,210
They should be able to get an rpm reading by logging a couple rpm points into the computer at different speeds in the gear you dyno in. Shops probably aren't familiar with doing that unless they do a lot of diesels. I know I wouldn't have any idea how, but I don't own a dyno shop either.
03-26-2014, 11:40 PM | #8 |
88
Rep 1,152
They work mainly on gassers and a few diesel trucks.
For the trucks they use a magnetic thingy attached to one of the pulleys and an optical tool to register the number of engine revs. One of the guys there was looking for the engine coils right after I told him it is a diesel car, and tried to pull the engine cover off after only detaching the engine oil cap. I stopped him. He is the one who placed the tape on the belt for the rpm readout. |
03-27-2014, 07:10 AM | #9 | |
614
Rep 2,410
03-27-2014, 08:49 AM | #10 |
229
Rep 3,489
Amigos I have the photos WHERE to hook up for the torque measurements I will post them soon ok
03-28-2014, 12:02 PM | #13 |
229
Rep 3,489
Here are the photos
03-28-2014, 06:54 PM | #14 |
213
Rep 2,210
Should be totally unnecessary if they know the system but if you need to be certain the rpm is exact the wire is good. By "the system" I mean the dyno, not the car
03-28-2014, 07:01 PM | #16 |
213
Rep 2,210
I assume its reading the pulses from either the cam position or crank position sensor, just like they would do for the coil wire on a gas car. No need to tap the wire. Its basically just an ammeter setup.
03-29-2014, 12:01 AM | #18 |
213
Rep 2,210
Could be accurate. The guestimate for auto trannys in the past was 25-30% depending on the trans. The new ones are much better, 20% is a lot better than 25%. I don't know that there are hard numbers you could find, everything I've ever seen is "my buddy has a friend who heard about a guy who said..." kind of stuff.
03-29-2014, 07:08 AM | #21 |
128
Rep 1,362
I made 294 whp/ 393 wtq
JBD @ 65-70% with a mustang dyno. I just can't find my sheet nowhere Now I'm running 100% but I always have to let it warm up before nailing it! |
