Fuel additives - destroyed injectors?
03-15-2014, 02:34 PM | #1 |
88
Rep 1,152
I had my injectors replaced recently.
I have been using some fuel additives to keep things clean for the engine. Would this be pure coincidence? Would the fuel additives possibly dislodged some residue and mess up on injector? Or just simple part failure? |
03-15-2014, 03:24 PM | #2 | |
851
Rep 2,793
My semi-educated guess would be that it was coincidental....how many kilometres:miles on the vehicle? |
03-15-2014, 04:44 PM | #4 | |
157
Rep 716
I had multiple injectors replacement without the use of additive. It is a common problem. |
03-16-2014, 09:12 AM | #5 |
23
Rep 133
who knows? there are just so many variables to consider
this guy convinced me to use the Standadyne additive, but im completely open to the possibility it may all be BS |
05-02-2014, 10:25 AM | #6 |
43
Rep 237
I brought back a couple of "dead" injectors by using Hot Shot Secret Stiction Eliminator in my diesel pick-up. According to a white paper on their site, a dead injector is more a oil problem than a fuel problem. The tiny amount of oil gets cooked inside of the injector and then fails. I use the stiction eliminator with the diesel extreme fuel additive to try to keep the injectors from failing again. 30k since I used it and they are still alive.
I emailed them about using their products in the 335D and am waiting for their response. I was originally interested in finding an additive that can boost my local diesel fuel from a 40 cetane to a 51 cetane as recommended by BMW. Maybe the higher cetane rating will burn cleaner and not have the CBU problems. |
05-02-2014, 11:10 AM | #7 |
229
Rep 3,489
Drives: Montego Blue 335d
I use AMSOIL products and so far so good at 42k
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
05-02-2014, 11:19 AM | #8 |
43
Rep 237
Since it sounds like you are always elbow deep in your engine, have you noticed any CBU since you started using the cetane boost?
Hot Shot replied and recommended a product called EDT. Will have to compare that against amsoil, royal purple and others. |
05-02-2014, 11:32 AM | #9 |
229
Rep 3,489
Car has been running great I hv had one limp mode and it was after not using Amsoil products for a month, turned off engine, then, back on went away then we ran the 1/2 mile twice which my mechanic drove till 150 mph on the 3/4 of mile, ever since that no problems. Cant speak for others
05-03-2014, 12:04 PM | #10 |
88
Rep 1,152
05-03-2014, 07:30 PM | #11 |
229
Rep 3,489
Dont jinx me dixy jajaja
