TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > boost numbers with torque app
      03-12-2014, 08:22 PM   #1
natefank
8
Drives: 335d
What is everyone getting for boost? I just got the torque app and I'm only getting like 25 psi max I thought stock was like 32 or 34 on these cars. Is there an adjustment on the app I need to change?
Thanks
      03-12-2014, 08:52 PM   #2
dixy2k
88
Drives: 335d
I got 32 a few times
      03-12-2014, 09:18 PM   #3
135i_vs_
135i_vs_'s Avatar
Drives: M5, 135i, 335d, F10 550xi
Little turbo goes to mid 30's and big turbo to mid 20's.
      03-12-2014, 10:24 PM   #4
Hoooper
213
Drives: 335D
You guys sure the peak numbers you're getting aren't boost spikes
      03-12-2014, 10:35 PM   #5
natefank
8
Drives: 335d
Hooper, what do u usually see?
      03-12-2014, 10:50 PM   #6
dixy2k
88
Drives: 335d
I floored a few times for a few seconds and the red dot on the dial (torque app) got to 32.
My answer is as good as the torque app can be accurate.
      03-12-2014, 11:06 PM   #7
Hoooper
213
Drives: 335D
Don't know, never had the interest to log it I guess
Was just curious, several other people have recorded a max of 26psi. Does the app convert the value internally or did you have to give it a factor? The DDE reports boost in hPa.
      03-13-2014, 07:06 AM   #8
TDIwyse
614
Drives: 2011 335d
Good question Hooper. Torque actually uses a "calculation" for its boost numbers. Relies heavily on the MAF input. In the Vehicle Profile, some things that impact boost accuracy include:
Engine Displacment of 3 litres, Volumetric Efficienty of 85%, and Boost Adjustment of 0. Try playing with those values. I played with those to bring the boost numbers inline with what the DDE reports (it reports absolute pressure by the way, which is normal atmospheric pressure + what the turbo adds).
The DDE for stock mapping is 26.5 psi max. Both the Evolve and Ecotune remap raised this to 30 psi.
Attached is a log from the Bavarian Technic tool recording directly from the DDE during a full fueling pull.
      03-13-2014, 08:58 AM   #9
dixy2k
88
Drives: 335d
Mine has the Renntech tune.
      03-18-2014, 02:31 PM   #10
dixy2k
88
Drives: 335d
After the dealer worked on my car replacing the injectors, I only get 29 PSI max boost.
      03-18-2014, 03:34 PM   #11
Hoooper
213
Drives: 335D
Any chance they flashed the DDE after all the work? That could overwrite part of all of your tune
      03-18-2014, 05:48 PM   #12
Chief Orman
Chief Orman's Avatar
Drives: 335D 2010
      03-18-2014, 06:29 PM   #13
dixy2k
88
Drives: 335d
That's what I think happened.
On the service ticket it says "reprogrammed with no further faults found". I understand the new injectors have to adapted to the DDE (or the other way around maybe) but a complete rewrite of the software.
Number 2, low boost numbers.
Number 3, no regen yet. Mine used to happen every 250 miles.
Number 4, subjective find... the car is not as lively as before.
I will dyno it next week to see what numbers she can put out.
