Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Fault Code: 43E2 Throttle Valve Actuator – 335D Help Please!
      03-12-2014, 12:21 PM   #1
Ek_1986
Ehs_1986
Ek_1986's Avatar
United Kingdom
Drives: BMW 335d
Hi All
I’ve got an E92 335D & have noticed a sudden of power. The fault code report is 43E2 Throttle Valve Actuator.
I’ve got a couple of questions if anyone can help with:
1) Has anyone had the same error code and if so how did you go about dealing with it
2) Which part is the fault code referring to? Is it the throttle body that bolts onto the EGR as per item (3) in the webpage contained on this link - http://www.realoem.com/bmw/showparts...69&hg=11&fg=40
3) Is this fault code likely to have symptoms of a loss power?
Thanks in advance to those that participate in responding to thread discussion
      03-12-2014, 01:44 PM   #2
m80theWolf
m80theWolf's Avatar
Drives: 2011 BMW 335d
When I first bought my cpo 335d a few months ago, I brought it back to the dealership a couple weeks later complaining that the car didn't seem very responsive on takeoff. I never had sudden loss of power. I can't remember the exact wording, but they replaced either whole throttle body, or just the actuator. After the fix, the car seemed more sprightly off the line. My car had 23k miles at the time.
      03-12-2014, 01:47 PM   #3
GreekboyD
411
Drives: 2009 BMW 335d
2009 BMW 335d  [8.00]
Yours might have been the turbo actuators/converters.
      03-12-2014, 01:49 PM   #4
Brad335d
Oil Burner
Brad335d's Avatar
What year D is it?
I'd like to look it up on my AllData but there could be a difference due to my system being a US car system and not a Euro spec system.
I would be willing to put my money on YES the #3 item is the throttle valve being referenced in the code you pulled.
Here's what I pulled from AllData for a 2011 335d:
2011 BMW 335d Sedan (E90) L6-3.0L DSL Turbo (M57Y)
Vehicle » A L L Diagnostic Trouble Codes ( DTC ) » Testing and Inspection » Manufacturer Code Charts » 43E2
43E2
43E2 - P2620
Information saved in
DDE
Fault code
43E2 - P2620
Fault text
DDE: Throttle-valve actuator, activation: Open circuit
Fault description
The DDE recognizes an open-circuit error at the output
stage:
Throttle-valve actuator.
Condition for fault identification
Test condition:
The check frequency depends on the process sequence
control.
Voltage condition:
control.
Condition for fault memory entry
Debounce (220 ms)
Action in service
Check wires and plug connections.
If wiring and plug connections are OK: Replace throttle-valve actuator.
Fault effect and breakdown warning
The error disables regeneration in the particulate filter.
Driver information
Warning light:
MIL
Service instruction
none
© 2014 ALLDATA LLC. All rights reserved. Terms and Conditions
'11 BMW 335d Sport
-JBD
'07 Shelby GT500
-Not Stock
      03-12-2014, 03:06 PM   #5
m80theWolf
m80theWolf's Avatar
Hrm. I'll check the maintenance records.
      03-12-2014, 03:13 PM   #6
Hoooper
213
Drives: 335D
Originally Posted by Ek_1986 View Post
Hi All
have not had the code, but I would guess its referring to the actual butterfly valve (throttle valve, anti-shudder valve, etc) and not the EGR. Would definitely have the potential for power loss if it is failed in any position other than wide open.
      03-12-2014, 04:41 PM   #7
Ek_1986
Ehs_1986
Ek_1986's Avatar
United Kingdom
Drives: BMW 335d
Thanks for the responses guys!
Brad335d - The D is a 2006 (56 plate) model.
Hooper – What do you mean by ‘actual butterfly valve (throttle valve, anti-shudder valve, etc)’ – are you to direct to a partnumber or indicate where this is? – Are you referring the part *3 in my intiail thread?
GreekboyD – Where are the turbo acutators/convertors located? Bottom of both turbos? Have you got a part number or a link to one that will help me in identifying where this is on the vehicle?
      03-12-2014, 04:55 PM   #8
Hoooper
213
Drives: 335D
I just wrote it that way because its really not a throttle valve but it is referred to sometimes as a throttle valve. Its really a butterfly valve that apparently serves a couple different purposes
