Help/advise need: cic controller retrofit problem
03-10-2014, 04:22 PM | #1 |
20
Rep 183
Hi guys!
Well my problem is quite simple in fact. I'm trying to retrofit the CiC controller in my car. Everything is working fine BUT I'm facing a problem with the center trim console... I have a poplar wood trim and this version was stopped before the CiC controller to come out on the market... I was planning to cut the trim with a dremel like shown on this post: http://www.m5board.com/vbulletin/e60...torial-12.html I ordered the same surrounding bezel but it's not large enough to cover the original CCC hole... there are 2 little gaps on both sides... So I'm stuck! I'm wondering if the surrounding bezel of the M3 is available and sold separately? I can't find the part alone on realoem... Can someone please help me by measuring the m3 bezel? Any other idea otherwise? Thanks!! |
09-04-2014, 05:36 PM | #6 |
18
Rep 315
the hole is way different... I'm pretty sure you can't fix with that little M3 extra
get a scratched (any trim colour) one off a later car and go vinyl wrap of something you like... might be better to try something that contrasts well... unless someone did a matching set up *(I doubt that) even the brushed aluminium lots had, is really replaced by a slightly different brushed steel effect one... |
