JB4 issues with saving settings?
03-07-2014, 10:01 AM | #1 |
Rep 49
I have a JB4 G5 ISO, and its not saving the settings that I select on menu controls 40mph-100mph. Ex I'll select boost on fuel and that will save fine (20mph) but then i'll enable stealth hi-jacking and it won't save. It will work only during that key cycle, if I re-enter back into the control menu it defaults back, if i shut the car off it defaults back. Same with the corvette gauge sweep option. If I re-enter the menu its gone, if i shut the car down its gone. Is this an issue with the firmware? Am I an idiot? Thanks
03-07-2014, 12:07 PM | #2 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
It's definitely not the firmware, but could be that you don't have the latest Interface Software download. A few of the menus selections are mutli functional. When you select are you "backing out" of the setting properly. That is, are you moving to the to the next or previous menu item correctly?
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
03-07-2014, 12:20 PM | #3 |
Joint Chiefs of Staff
4918
Rep 115,980
Sounds like it's working normal to me. Certain menus default to 0 regardless of what settings are saved. If you are looking for menu 4 to jump up to 1 because you enabled "stealth mode" last time around it won't. It will always jump to 0 regardless of the stealth mode setting.
Mike |
03-07-2014, 12:40 PM | #4 | |
Rep 49
Jury's verdict, I'm an idiot. I drove it down the road and the boost gauge was activated from stealth mode. I'm just paranoid, first time modding a bmw coming from the mustang world. |
11-10-2015, 05:26 AM | #5 |
Rep 2
Hey mike,
I am suffering from the same issue on my 08 335i e90. When i try to activate stealth hijacking, it will never show boost even if full throttle. Any idea why that could be? If the stealth mode is activated, which gauge would be hijacked? |
11-10-2015, 09:20 AM | #6 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
You need to add boost to one of the gauges. Stealth mode won't do anything if nothing is set to display on the gauges. Select 2/1 to enable boost on fuel gauge. It will display boost (0-20psi) when the pedal is depressed more than 50%.
11-10-2015, 09:38 AM | #7 | |
4918
Rep 115,980
Stealth mode only tells the JB4 to activate the gauges at >50% throttle. You still need to config the gauges as you want. Mike |
