Blow off valve: To recirculate or not to recirculate
03-06-2014, 06:25 PM | #1 |
435
Rep 412
I know it doesn't really matter, but just want some of your guys' advice/opinions.
My set up is a 335is with DCI, OCC, ETS CP, HKS bov, generally running map 1 on jb4. I've tried both, I would just like to be educated. |
03-06-2014, 08:52 PM | #3 | |
435
Rep 412
03-06-2014, 09:08 PM | #5 |
86
Rep 1,262
It really doesn't matter. Recirculating the charge air is only necessary in MAF (Flow sensor before the turbo) cars, like the Audi/VW's etc. MAP (Pressure & Temperature sensor after turbo) cars like ours don't care if the charge air gets vented to atmosphere or not.
Do whatever you like! If you think the noise is neat, VTA. If you think it's too loud, recirc!
Josh-
03-06-2014, 09:10 PM | #6 | |
435
Rep 412
03-06-2014, 09:15 PM | #7 | |
86
Rep 1,262
Where do you recirculate to? one of the stock DV ports?
Josh-
03-07-2014, 08:25 AM | #8 |
421
Rep 1,643
Before deciding to my dv's or bov, I asked one of the popular tuners on here who said you want a dv so that the air recirculates. Can't exactly remember the reasons he cited though.
Edit: just noticed you were only considering bov, I'm guessing the same idea about recirculating could apply ...
2007 E92 335i MT
03-07-2014, 04:40 PM | #9 | |
N54 E92
51
Rep 342
Light Bolt-ons, Tunes, & Methanol Injection: 12.30 @ 115mph [2.0 60ft on Street Tires] [91 Octane] 1.59 Seconds Faster than Stock [as of 05/29/2014] Previous Vehicle: '65 Chevelle [LSx 6.0L/4L80e] |
03-08-2014, 12:46 AM | #10 |
143
Rep 567
I have my synapse recirculated. It was way to loud for my taste and I do not like the chance of unfiltered air getting in. People claim it is always blowing but there are times where it seems like it is pushing air and other times it is not.
03-08-2014, 01:36 AM | #11 | ||
435
Rep 412
03-08-2014, 02:07 AM | #12 |
143
Rep 567
It needs to recirculate pre turbo. If you are recirculating by the throttle body you are pretty much looping the bov/DV and not letting off any boost
07 335 6MT
03-08-2014, 02:16 AM | #13 | |
435
Rep 412
03-08-2014, 07:41 AM | #14 |
7
Rep 172
By having the hose from your BOV going to somewhere between the intake and the turbo?
Like what the stock diverter valves do. From the turbo>>intercooler>>throttle body is a pressurized system under boost. If you are recirculating back into this section of the system, the air isn't going anywhere and you aren't relieving pressure from the system. What you will actually cause is air blow back through the turbo blades.. ie flutter noise. Sounds cool, not the best way to do it. Might as well have no BOV at all if you are doing this. |
03-08-2014, 09:13 AM | #15 |
86
Rep 1,262
I agree, our engines pull more vacuum than a typical turbo 4, I've caught mine uncomfortably close to no flow while open, so I slapped a 3" K&N filter on it. Muffled the noise a bit too. Where do you recirc it to?
03-08-2014, 09:52 AM | #16 |
181
Rep 1,681
Unless the spring is messed up or there's a leak, it shouldn't draw air in. Never had any issues on any turbo car over the years with venting. Right now only downside with the BMW cowl filter is that some fumes get into cabin from the vented air. Not a big deal.
03-08-2014, 09:54 AM | #17 |
265
Rep 1,392
Ideally you want to recirculate. It's less suction the turbo has to do, quicker spool, air has already cooled, and more. You will have more performance out of recirculating over atmosphere.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust 335i 2009 e90 665RWHP VFF900 ST RIP . |
03-08-2014, 12:42 PM | #18 |
17
Rep 151
I've ran the stock diverter valves and then switched to a ER charge pipe with Tial Q BOV (installed yesterday). Runs more or less the same.
It's all up to you and your sound preference. Been running vent-to-atmosphere BOVs for years on many turbo-equipped vehicles and never had any issues due to using them. And they sound kinda cool...but ricey. I chose the Tial Q because it's really not loud at all. |
03-08-2014, 01:29 PM | #19 | |
435
Rep 412
03-08-2014, 02:00 PM | #20 |
143
Rep 567
There is no bolt on solution for recirculating a blow off valve. I loved my recirculated diverters but it left no room for any intake other than dci's. I switched to a synapse and made a custom mr5 style intake. In the tube there is a 1 1/4 bung. It takes some fab work but turned out to be good clean solution. I imagine you could recirculate into one of the stock ports and leave the other capped but I wanted it discharging evenly into both banks
Synapse solution: Diverters
07 335 6MT
03-08-2014, 02:15 PM | #21 | ||
265
Rep 1,392
03-08-2014, 03:01 PM | #22 |
Accepting Donations
9
Rep 333
Drives: Montego Blue E92
ECS has OEM and Forge DV's
2009 Montego Blue E92 Sold
