SES Code P02D1
03-06-2014, 06:04 PM | #1 |
88
Rep 1,152
SES Code P02D1
Just got this fault code today.
Torque app can only say powertrain and nothing else. I think the engine still pull strong, however there is something weird about the tranny. I can't say for sure but it seems as if it doesn't shift in a lower gear upon demand. Any input? |
03-07-2014, 10:37 AM | #2 |
Oil Burner
26
Rep 231
4AF5 - P02D1
Information saved in DDE Fault code 4AF5 - P02D1 Fault text DDE: Zero-quantity adaptation, injector, cylinder 3: permissible filtered activation duration correction too high Fault description Monitoring zero delivery rate adaptation. The diagnostic trouble code is logged when the corrected injection activation period at one of the 3 calibration points exceeds the maximum activation duration and when the signal deviation at one of the 3 calibration points exceeds the signal limit. Condition for fault identification Test condition: Monitoring proceeds in a 100 ms grid. Voltage condition: Monitoring proceeds in a 100 ms grid. Condition for fault memory entry Event debounced (1) Action in service Replace injector. Fault effect and breakdown warning - Driver information Warning light: MIL Service instruction none © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions
'11 BMW 335d Sport
-JBD '07 Shelby GT500 -Not Stock |
03-07-2014, 05:24 PM | #5 | |
109
Rep 429
03-08-2014, 10:52 AM | #6 |
88
Rep 1,152
03-08-2014, 10:55 AM | #7 |
88
Rep 1,152
Thanks Brad
I took the car at the dealer Friday afternoon. I was told they will get to it on Monday. Meanwhile I drive a 535d loaner. I like it a lot. Seems to have less power than mine. Currently my car lacks some power in the low RPM range, it wakes up around 3000 RPM. I thought the first turbo was at fault again. The engine revs fast but there is a lack of (perceived) boost. |
03-08-2014, 11:33 AM | #11 |
281
Rep 4,121
03-08-2014, 03:25 PM | #13 |
213
Rep 2,210
There is actually a tsb that blames the zero adaptation fault on a bad DDE. The situation listed in the tsb is very specific but to me it suggests there is/was a DDE issue. You wouldn't be the first one on here to have that fault because of a DDE.
03-08-2014, 04:02 PM | #14 |
281
Rep 4,121
As I've posted before, the e90 US 335d (DDE7 vs EU DDE6) has gone through no fewer than NINE part numbers since product introduction! It is quite clear they are having some unspecified QC issue with it.
03-10-2014, 07:39 PM | #16 | |
88
Rep 1,152
Is it still not enough for some of those issues? Doe the whole thing need to be replaced? BTW, it's the end of the day now and the dealer hasn't called yet. |
03-10-2014, 11:45 PM | #17 |
213
Rep 2,210
I think its a hardware issue. The TSB advises replacement of the DDE rather than a reflash
03-11-2014, 02:46 AM | #19 |
Curmudgeon and Pedant
690
Rep 3,489
03-11-2014, 02:49 PM | #21 |
88
Rep 1,152
Got a call back from the dealer.
Apparently they will replace all injectors under emission warranty, but there is one more thing bad with it. The DEF module has gone bad and it cannot read properly the amount of liquid inside the tank, the SA also said it cannot read the amount of fuel inside the tank (I know this is just huge BS). The cost of replacing the module is about $700, not covered under warranty. |
