N54 Boost question
03-05-2014, 09:17 PM | #1 |
Rep 23
N54 Boost question
I've doing some searching but can't get a straight answer.
My question is, the stock set-up for the N54 boost is 8 psi. Is that boost sustained or is it peak boost? |
03-05-2014, 09:27 PM | #2 |
456
Rep 6,478
Peak- though it pushes about 8ish pounds for most of the curve.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
03-05-2014, 09:29 PM | #3 |
34
Rep 1,093
Not sure if your serious. I can't think of any forced air system that maintains a sustained boost level through the rpm band. The 8psi is peak boost. IS cars can be as high as 14 apparently.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
03-05-2014, 09:54 PM | #4 |
38
Rep 634
Depending on customer request/vehicle intended use we have tuned cars to peak and hold 12psi from 3K to redline.
03-05-2014, 10:04 PM | #5 | |
34
Rep 1,093
EDIT: I'm referring to a sustained number of let’s say 8psi. Thought I would clarify.
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system Last edited by Ingeniator; 03-05-2014 at 10:07 PM.. Reason: Clarification |
