Running Cobb Stage 1+ FMIC - Error Codes
03-05-2014, 03:10 PM | #1 |
15
Rep 115
So, I have been running Cobb Stage 1+ FMIC since November without any issues until last week. (2010 335XI, 38K miles)
Right after I filled up at BP, I hit the petal and all of a sudden engine light comes and and every time I pushed the gas, the car would majorly hesitate (The car felt very shaky as if I had a flat tire). I shut the car off, turn it back on, engine light went off, then as soon as I punched it again, same thing. I pulled the codes and got the following: P29D1 - Misfire, Cylinder 5 H29CE H2FCA H2FDA I uninstalled the COBB software, ran the car for several days and no issues whatsoever. Since I accidentally cleared the codes, and my car is still under FULL warranty, I decided to put the software back on to see if I could get the codes to appear again (So I could bring it in to BMW). The last 2 days, my car has run perfect. NO issues whatsoever. Only difference is I filled the tank up. So, here comes the stupid question. Could bad gas possibly of been the culprit? 2 minutes after first fill up, problem kept occurring. After new tank of gas, zero issues?
2010 335xi Coupe | M Package
COBB Stage 1+ Aggressive FMIC | aFe DCI | Helix FMIC | VRSF CP 2011 535diI Last edited by buylongterm; 03-05-2014 at 03:32 PM.. |
03-05-2014, 04:07 PM | #2 |
32
Rep 572
P means a present code
H29CE- Combustion misfire cylinder 2 The other two relate to a potentially bad fuel pump. See: http://www.e90post.com/forums/showthread.php?t=660403 It's possible bad gas caused the P code, but not sure on the others. Basically though the only code your getting ride now is the P code as the others I believe relate to past codes thrown. P indicates still Present.
2011 335i Sedan M Sport/Le Mans Blue Metallic/Glacier Aluminum Trim/Heated Seats/Premium Package/Black Leather/Ipod Adapter/Paddles/FormulaOne Tint/Matte Black Grilles/AA Signature Exhaust/AA Chargepipe/ Cobb Stage 1 Aggressive [SOLD]
2007 328i Coupe Sport/Matte Black Kidney's/3M Tint----Lemon'ed [SOLD] |
03-05-2014, 04:17 PM | #3 | |
15
Rep 115
COBB Stage 1+ Aggressive FMIC | aFe DCI | Helix FMIC | VRSF CP 2011 535diI |
03-05-2014, 04:59 PM | #4 |
32
Rep 572
I had problems a while back and I cleared them and they never came back. Sometimes its just bad gas like I said. If it comes back then I would get it checked out but otherwise, I wouldn't worry to much about it. My problem was fuel mixture related.
03-06-2014, 12:22 PM | #5 | |
15
Rep 115
Thanks! Much appreciated.
03-06-2014, 12:55 PM | #6 |
258
Rep 1,084
When you uninstall your Cobb it automatically clears any codes...
Sometimes getting the car to reproduce error codes stock can be difficult... Hope it was just bad gas, congrats on the tune |
03-06-2014, 01:00 PM | #7 |
65
Rep 554
Drives: E92 335i 6MT
Be wary, I had misfire and fuel pump related codes, cleared them and I was ok for a week or so then my HPFP took a dump. I was driving hard and couldn't re-create the initial limp mode/codes, once it failed I couldn't go past 2k RPM without going into limp mode.
03-11-2014, 01:31 PM | #10 |
15
Rep 115
Yep, issue came back. I uninstalled the software and since car is under warranty, I have an appointment on Thursday. My question is if uninstalling the software clears the codes, then how can I prove to the dealership I'm actually having an issue???
Is it possible to show them the screenshot I took of the codes and tell them a buddy of mine who works on BMW, accidently cleared the codes? I know it sounds EXTREMELY stupid, but I want them to replace plugs and possible HPFP
COBB Stage 1+ Aggressive FMIC | aFe DCI | Helix FMIC | VRSF CP 2011 535diI Last edited by buylongterm; 03-11-2014 at 01:45 PM.. |
03-11-2014, 03:13 PM | #12 | |
15
Rep 115
BTW, can you recommend any decent plugs? what about the coils? Thanks!
COBB Stage 1+ Aggressive FMIC | aFe DCI | Helix FMIC | VRSF CP 2011 535diI Last edited by buylongterm; 03-11-2014 at 03:25 PM.. |
03-11-2014, 03:20 PM | #13 |
3441
Rep 79,211
Go with new stock plugs. Of if you want to gap plugs yourself you can get the NGK's we sell.
03-11-2014, 03:29 PM | #14 | |
25
Rep 755
Car: 2007 e90 335i 6MT - sports, premium, cold weather, light, and smoker's package. Performance Mods: Cobb AP v3, ETS 7" FMIC, Injen DCI, Michelin PSS, CDV delete, rear spoiler, BMW PE w/ Magnaflow tips, PTF pro-tune, VRSF downpipes, ER chargepipe w/ Tial Q, APEX 18" EC-7 wheels, MP outlet/ inlet, MMP Stg. 3 turbos. Other mods: BMW cargo liner, 20% window tint, BMW alarm system, Weathertech floorliner, Lux E90 V6 bulbs, Philips X-treme Vision H7 bulbs, Blackvue DR650GW-2CH.
03-11-2014, 03:39 PM | #15 | |
15
Rep 115
EDIT. Forget that. I just found out BMW could charge me well over 350.00 to replace. Do I really need some BMW specific tool to do this? can I find it on Amazon?
COBB Stage 1+ Aggressive FMIC | aFe DCI | Helix FMIC | VRSF CP 2011 535diI Last edited by buylongterm; 03-11-2014 at 03:50 PM.. |
03-11-2014, 03:49 PM | #16 |
15
Rep 115
Are these the correct plugs?
http://www.amazon.com/Bosch-ZGR6STE2...ype=automotive And the tool??? http://www.amazon.com/Assenmacher-Sp...park+plug+tool
03-11-2014, 03:51 PM | #17 |
25
Rep 755
Everything needed can be purchased off Amazon or ebay for cheap. The dealer will charge you at least a couple hundred for something as simple as a spark plug/coil change. If you don't want to do the work yourself then either the dealership or a third party BMW auto shop will gladly do it.
03-11-2014, 03:58 PM | #18 | |
25
Rep 755
Both work with your car. Don't forget the Bosch ignition coils.
03-11-2014, 04:02 PM | #19 |
15
Rep 115
thank you. Trying to find the correct ones on Amazon...
03-17-2014, 09:57 AM | #20 |
15
Rep 115
Update:
Replaced all spark plugs yesterday and though it was a MAJOR pain in the ass, my car is running fantastic! "knock on wood", no codes so far. And though I know spark plugs cannot increase HP, I do notice my car seems to be driving a lot better/smoother. As crazy as it sounds, it's like driving a new car. The video above was a HUGE help. Thanks everyone for all advice/help.
03-17-2014, 10:15 AM | #21 |
77
Rep 2,114
If your plugs were weak and kicking the bucket, it's no surprise the car is running smoother. Strangely, I had ar design swap mine @ 45,000 and I'm at 46,000 now. I honestly couldn't tell a difference. All I know is the plugs are on my maintenance schedule now rather than an unknown life span from the previous owner. Preventative maintenance on this engine is pretty much an essential part of being tuned.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
03-17-2014, 10:55 AM | #22 | |
15
Rep 115
