Logs showing individual cylinder timing correction
03-05-2014, 01:19 PM | #1 |
305
Rep 166
Any of you guys have logs that show the the timing corrections for each individual cylinder? I'd be curious to see them if you'd care to share.
Also, for any of you that had one unhappy cylinder, what solutions did you apply? |
03-05-2014, 01:25 PM | #2 |
65
Rep 385
All of my logs. Normally they're clean; no timing pulled in any of the cylinders. When there is noise, typically I'll get a few degrees of timing pulled in 1 cylinder, and you can see it rapidly decreases to 0 pulled timing over the next several lines of the log. Not something to be concerned about unless you see it recurring. Normal order of troubleshooting is to confirm there is a problem, then check coils, plugs, and injectors (IMO, in that order but doesn't matter).
