TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Joining the catch can crew!
      03-04-2014, 08:17 PM   #1
Nushibo
Nushibo's Avatar
23
Drives: 335D
2011 BMW 335d  [0.00]
Well after an entire day of learning and breaking things I finally got the can in.
I'd like to thank Mark M , Doc, J and few for taking those initial steps.
Its not perty but it works, fully reversible when I purchase the part i broke Lol its the 4' flex pipe.
http://www.realoem.com/bmw/showparts...91&hg=13&fg=20
Item# 5 for future reference lol
      03-04-2014, 08:44 PM   #2
Mark M
Mark M's Avatar
Drives: E30M3 E83X3 E90335D
Great work. Looks good. How is the can mounted in that location? Appears that might save about 3 total feet of hose run from where I have mine back on the strut bar. Less hose run is a good thing.
Thanks for sharing.
      03-04-2014, 08:57 PM   #3
Nushibo
Nushibo's Avatar
23
Drives: 335D
Thanks for sharing.
Its not truly mounted yet. Its held down by gravity and back force from the tubing. I removed the switch box/breaker from its place and sat it to the side near the ballast for HIDs. Ill be fabbing up some brackets to use. Where the can is now was that switch box/breaker. id been eyeballing it for some time.
Removing the switch/breaker takes two black nuts leaving behind two welded or attached whats that word i guess screw point? I sat the can on the botton point, and leaned it against the top point. the hoses hold it in place.
      03-05-2014, 02:38 PM   #4
Ajs_435d
Ajs_435d's Avatar
355
Drives: 435d m sport m performance
Hi thanks for posting.
I'm looking to fit one to my euro 335d. I'm just a little lost.
Is it just a case of fitting those rubber pipes to what looks like a T peice?
What is item number 5 for?
Just wanting a brief idea how to install it and where to put the pipes. I have only had my 335D 3 month and just familiarising myself with it, I have looked under the engine cover.
I've fitted them on petrol cars, but also have a vent to atmosphere filter or dump to ground as you dont want a pressure build up IYKWIM - does the same apply for a diesel?
Thanks
      03-05-2014, 05:08 PM   #5
TDIwyse
614
Drives: 2011 335d
I'd like to encourage you to keep an eye on this area in the pic. Looking at my setup it seems that how you have that routed could place you in danger of condensation pooling/collecting and/or freezing and obstructing ventillation. I've been using clear tubing with my setup at first to get a feel for what's going on in the system and how much moisture is present. It's more than you might expect if you use black hose and never look...
http://www.e90post.com/forums/showpo...&postcount=352
      03-05-2014, 06:28 PM   #6
Nushibo
Nushibo's Avatar
23
Drives: 335D
Thanks for the tip, I tried to keep everything as level as possible. Ill probably end up taking it apart at or around 500-1000 miles just to see how things are holding up. Not too worried about freeze since im in florida, and the heat should keep the oil, air in mist form until it hits the can. Ill update in about a weeks or two time since I drive that much lol
Thanks
Item number five is the piece that connects the PCV vent hard line to the Air intake. Not sure how different euros are but you could send a few questions to doc as hes done a Euro spec 335d, refer to the links below to give you ideas. I'll probably attempt a DIY later down the road after looking at how this setup goes. Not sure how much of a problem pressure will cause seeing as how 2011d PCV pipes are ECU monitored if i recall. someone correct me if im wrong.
Heres his reference link:
http://www.e90post.com/forums/showth...ther+catch+can
Look here if youre needing more info on this project.
http://www.e90post.com/forums/showthread.php?t=867543
      03-06-2014, 11:46 AM   #7
135i_vs_
135i_vs_'s Avatar
Drives: M5, 135i, 335d, F10 550xi
Looks great.
Can you tell us about the 90 degree elbows you used? Size, part #, website?
Assuming these are 90 degree PCV elbows generally sold at Auto Stores.
Thanks,
      03-06-2014, 11:56 AM   #8
Mark M
Mark M's Avatar
Originally Posted by 135i_vs_ View Post
Looks great.
Thanks,
The ones I used were Help Item 47043. Google it. They are at just about all auto stores.
      03-06-2014, 02:50 PM   #9
Nushibo
Nushibo's Avatar
23
Drives: 335D
Used those same ones. Most autozones or advanced autos should have them.
      03-07-2014, 05:27 AM   #10
Puerto Rican 335d
Puerto Rican 335d's Avatar
Puerto Rico
229
Drives: Montego Blue 335d
Nushibo can you post a video on this if possible
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD
Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now)
      03-07-2014, 05:22 PM   #11
Nushibo
Nushibo's Avatar
23
Drives: 335D
Ill post a video on how to get to removing air intake, and at the other junk but beyond that its a bit tricky. I should be able to do it quicker since I have more tools haha. Thank you Harbor Freight sale. But yes ill try to do one for you.
