JB4 2step help. Won't save setting
03-02-2014, 03:57 PM | #1 |
N
31
Rep 631
Just installed it this weekend and I seem to be able to set everything else but the 2step. I go to 8, then set an RPM, save, then nothing, no 2step. Is there something additional I have to do to get this to save?
03-02-2014, 05:41 PM | #2 |
33
Rep 578
What RPM did you set it to?
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
03-02-2014, 11:39 PM | #5 |
33
Rep 578
Keep your testing above 3500, I believe 3200 or so is the starting point anything below that it disables the feature. The clutch doesn't have to be all the way in to trigger the switch. I would double check all the wiring.
03-03-2014, 06:34 AM | #6 |
N
31
Rep 631
03-03-2014, 03:10 PM | #7 |
41
Rep 692
