03-02-2014, 05:55 AM | #1 |
14
Rep 113
JB Stage 1 + DP = Codes??
I know you can delete codes with the Jb4 Stage 2 but cannot with stage 1. But will a Stage 1 plus a downpipe throw any codes? I ask b/c I plan to get stage one then maybe adding a dp down the line. I'm assuming yes due to the dp alone. Is this correct?
Also, what kind of max power difference can you expect with this combination vs stage 2 + dp + different maps? |
03-02-2014, 12:21 PM | #2 |
92
Rep 586
[QUOTE=MicrophoneMic;15531897]I know you can delete codes with the Jb4 Stage 2 but cannot with stage 1. But will a Stage 1 plus a downpipe throw any codes? I ask b/c I plan to get stage one then maybe adding a dp down the line. I'm assuming yes due to the dp alone. Is this correct?
Also, what kind of max power difference can you expect with this combination vs stage 2 + dp + different maps stage 1+dp about 325-330whp stage 2 map2+ dp 350-355whp .. based on terrys dyno .. so its about 20-25whp difference which u'll deff feel .. + u can put some e85 and on map7 i'll be about 45-50whp more .. so stage 2 deff worth it over stage 1 if u plan too do dp... |
03-03-2014, 10:46 PM | #3 |
BimmerPost Supporting Vendor
24289
Rep 190,975
Yep go with stage 2
