Car running very different, 2caa 2ca6???
03-01-2014, 08:13 PM | #1 |
8
Rep 74
Drives: 2009 BMW 335i E90 6mt
Ok, so Im new to turbo engines. Ive had the jb4 installed for awhile, however just got catless downpipes and fmic installed, and now im throwing the 2caa and 2ca6 code. I know those are for the 02 sensors at the downpipes. My car is not running very well, feels like theres no boost. I have dci's and i dont even here them going. I hear the turbo spool, and the my boost gauge shows pressure and then drop off within milliseconds. Can bad 02 sensors cause this? Much help appreciated!!
03-01-2014, 08:42 PM | #2 |
8
Rep 74
oh yea, im not misfiring at all!
04-12-2014, 02:55 PM | #4 |
8
Rep 74
Just an update, it was a huge boost leak, but that didn't throw the codes. It was actually a misfire, bank 1 sensor 1. I finally went g5 iso, and kept getting thrown into map 4 from any map. Finally replaced my 02 sensor yesterday, and all is well. No more codes!
2009 BMW e90 335i 6mt-VRSF 7" FMIC, VRSF Dp's, JB4 G5, BMS DCI, CF Vinyl Exterior Trim, CF Vinyl Interior Wrap, M Performance Shifter, M Performance E-Brake, Front Mtech Bumper, Rear Mtech Bumper, Stop Tech Slotted Front and Rear Brakes, Michelin Super Sports.
04-12-2014, 03:44 PM | #5 | |
12
Rep 348
Drives: 2009 E92 335i
did you use the Downpipe fix from BMS, when you run the downpipes you can throw codes. the downpipe fix will correct this issue |
04-12-2014, 04:27 PM | #6 |
8
Rep 74
well the code is just for 1 02 sensor. But now that my 02 sensor was replaced, im not throwing any codes... and I have the jb4, so no bms fix.
04-12-2014, 04:43 PM | #7 |
18
Rep 380
just got this same code after downpipe install, was it hard to replace o2 sensor?
07 E92 335i -BSM- Sport- iDrive- Premium- Cold Weather- Aero Lip- M3 Trunk Lip- Injen Dual Cone- Posi Quiet Ceramic Pads- R1 Premium Cross Drilled Rotors- H&R Sport -JB4+Ethonal- - Raceland DPs - Avant Garde M310- Alpine TypeR 10''- Alpine MRP-M500 Amp |
04-12-2014, 04:48 PM | #8 |
8
Rep 74
well for me it was since my jack wont fit under my car, and I cant get on ramps lol. If you can lift your car, not at all, just follow the wire. If its the same exact code, you can use the bosch 02 sensor. I got mine at oreilly's for like 159 bucks. I had a shop install it for me for like 30 bucks since they have a lift. Just remove the engine cover, on the right side, youll see where the 2 sensors go in, its the first one, the black one. You might need to get a tool from, auto zone or another parts store, its an 02 sensor removal tool.
04-12-2014, 05:04 PM | #9 |
18
Rep 380
strange, mine was working fine until i installed downpipes this morning. i also heard that if the wire cover isn't covering the metal it could trip the o2 sensor. So i'm going to try that since my wires were exposed. luckily my car is jacked up now, so if this doesn't work then i guess i'm going to have to bite the bullet and buy new o2 sensor.
someone also said clean the maf sensor too.
04-12-2014, 08:53 PM | #10 |
Senior Troll
224
Rep 3,378
hi,
i got those exact code right after my dp install, prior that my car had no faults. were you sure that the o2 plugs are plug in the right order? have u look again to check if any codes? my car is going back to the installer on monday to fix this issue so im trying to figure out the exact problem. btw did you lower the steering rack during install? my steering feels lighter now so i am not sure what is wrong. cheers
Gone:
N54 335i is the Legend! N55 435i Now: 718 Cayman GTS / F83 M4 |
04-12-2014, 10:18 PM | #11 | |
8
Rep 74
Are you n54 or n55? N54 only has T-map not maf, so I knew that couldn't be it lol. Your wires might be twisted, but probably not. I would uninstall it, and re-install correctly, if that doesn't work, time for a new sensor! Go Bosch, same thing as oem but half the price lol.
04-12-2014, 10:25 PM | #12 | |
8
Rep 74
04-12-2014, 10:26 PM | #13 |
8
Rep 74
Haha this was right after I got my car back. It was actually a little worse
04-12-2014, 10:51 PM | #14 | |
Senior Troll
224
Rep 3,378
can u tell mewhich o2 sensor did you replace? also did you notice any fuel smell coming into the cabin? i had a cracked aircon pipe last summer and i am not sure if its me or its normal that the car is dragging fumes from the engine in so easily or my dealer done a crappy job and some intake hose it not fitted on properly?
Gone:
04-12-2014, 10:53 PM | #15 |
Do it for a living.
60
Rep 144
i've read from terry @bms that you're not supposed to run with the DPfix installed at all times. its should only be used temporarily when needed. apparently it messes with long term fuel trims if i remember correctly. makes sense, the car should not need simulated o2 sensors to run properly, only to pass emissions readiness. the jb4 will suppress the CEL anyway.
04-12-2014, 11:00 PM | #16 | ||
8
Rep 74
Yes it was bank 1 sensor 1! So upstream cylinders 1-3! When you take the engine cover off, you'll see where the sensors plug in on the right hand side. It's the black one. If you can get under it, just take your the pan off, and you can see the 02 sensor. And yes, I'll smell fumes here and there, and when I'm pushing the car pretty hard, at a stop I'll get the rotten egg smell, however ever since I replaced the 02 sensor, no fumes smell, and I went and put some e85 earlier and pushed the car pretty hard and no rotten egg smell either lol.
04-12-2014, 11:01 PM | #17 | |
8
Rep 74
12-07-2023, 11:57 PM | #18 | |
Rep 72
Drives: BMW 335i
Finally someone talks about the annoying 2C3D code!!!! Never imagined that it was related to 2CAA and 2CA6 codes The faulty O2 sensor could harm the performance? I mean boost build, PSI level, HPFP operation, et al. |
