The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Problems with JB4
      02-28-2014, 10:19 PM   #1
alex492
Drives: 2008 BMW 335xi
Exclamation Problems with JB4
So I've had the jb4 installed on my 2008 335xi since about march of 2013 and never had any troubles until this winter. Whenever turn on the map (map 2 because I have downpipes) and floor it from a stop, it jerks at about 5000rpm in first and then in 2nd it loses all power and the service engine soon light comes on. So when this happened I immediately stopped the car and had it in idle and it ran extremely rough making weird noises. I then turned off the car and turned it back on again and it was fine. But same thing keeps happening when I floor from 1st to 2nd, loses power and light comes on.
Does anyone know whats wrong?
      02-28-2014, 10:29 PM   #2
stashtrey
294
Drives: 08 E90 335xi TiAg
Check your coils. Did you pull codes? Sounds like plugs or coils.
      02-28-2014, 10:31 PM   #3
jayzF30
34
Drives: '07 335i, '09 M3
Check your codes
      02-28-2014, 10:32 PM   #4
HeavyMetalRocker
HeavyMetalRocker's Avatar
Drives: 2007 BMW 335i E90 6MT
That is a misfire man, go read the misfire sticky. Nothing is wrong with your JB4.
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
      03-01-2014, 12:25 AM   #5
MikeE90NC
22
Yep, plugs, coils or injectors.
      03-01-2014, 02:13 AM   #6
07tundra
Drives: 8.1L Chevy 2500hd
How about you go to the correct forum like n54tech and post this in the support section and you will have tons of support. Terry will probably answer you himself.
      03-01-2014, 11:09 AM   #7
Acekid187
Acekid187's Avatar
Drives: E92 335i, E90 335i
I had the same problem. It was a misfire. I changed out all the plugs an its been fine. I even started running more boost never had a issue after changing plugs
Tags
335xi, engine problem, jb4
