The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Throwing a bunch of codes - loss of power, please help
      02-28-2014, 10:19 AM   #1
davidkotok
17
Drives: e92 335i
Hi All,
Been running a jb+ for around 45k miles and it has been awesome. I had been having some misfires a few months ago but after a walnut blasting and spark plug change the car has been great again; I also installed a BMS catch can while doing this and a DCI. I recently removed the jb+ to upgrade to a jb4 g5 (not yet installed) and have been running stock for about 3 weeks with no issues at all. Last night I took a drive and when accelerating in second gear i noticed it was a bit hesitant in the midrange but didnt really worry... After leaving the concert i went to and waiting to warm up when i was around 6-6500 in 3rd the car went into safe mode and turned off the turbos. I went into neutral (after returning to cruising speed) and hit the power button three times to turn off and then turned the car back on and everything was fine. Was getting good boost down low in all gears but was able to replicate the problem in the higher ranges of second gear.
Today i went to pull codes to see what was the issue and i got the following:
-2AAF
-30FE
-3100
can anyone give me any advice for how to deal with these 3, i have seen a few posts about having one or the other but would love some advice.
Terri@BMS I know you're an expert with this stuff, if you have any thoughts would really appreciate it.
Thanks everyone!
      02-28-2014, 04:12 PM   #2
davidkotok
17
Drives: e92 335i
anyone?
      02-28-2014, 04:23 PM   #3
135Pats
135Pats's Avatar
Drives: A few BMWs
Believe 30FE is an overboost code but not positive.
2AAF is a plausibility shadow code, I wouldn't worry about that in isolation.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      02-28-2014, 05:12 PM   #4
Danny_Cin
Drives: e92 N54
Had the same issue and turned out to be plugs. I would start with that again and see what happens. Then move to coils and then injectors. It's good that you did walnut blast it as the carbon build up on the valves( infamous problem with direct injection vehicles) as it will cause the vehicle to run sluggish and in some cases misfires. Sounds to me like you may have a bad coil or injector or hopefully not both. Good luck with the issue man I hope it's just the coil(s) for your wallets sake.
      03-01-2014, 08:59 AM   #5
davidkotok
17
Drives: e92 335i
i'm not getting misfires.... but thank you for your thoughts.
those codes are in regard to a boost leak and underboost. anyone have boost leak/ underboost issue?
      03-01-2014, 09:06 AM   #6
Ingeniator
Ingeniator's Avatar
34
Drives: 07 335XI(90) 09 135I(82)
Check all vacuum lines ensure they are pliable and look perfect if not change them. Check your charge pipe and intercooler connections to ensure they are tight and pressure test if yu have shop air. Check factory diverter valves(Likely culprit) to ensure they are working properly. If all these are correct it is turbo related and usually wastegates/actuators.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system
Tags
2aaf, 30fe, 3100, codes
