Cobb and NYC.inspection
02-26-2014, 06:05 AM | #1 |
284
Rep 1,132
Hey guys ,
I wanted to know do I have uninstall cobb for my inspection or will I pass without any problems if it is installed .? An no I do not have dps . I'm simply running stage1 Fmic aggressive Thxxx |
02-26-2014, 06:31 AM | #2 |
172
Rep 2,347
you will pass
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
02-26-2014, 09:00 AM | #4 | |
284
Rep 1,132
I knew if i uninstalled it would have to wait a few days before going to do the test. I have heard of ppl passing with it , but i was not 100% sure. I only have heard of ppl failing if they have dps without a dp fix. |
02-26-2014, 11:05 AM | #6 |
Joint Chiefs of Staff
4918
Rep 115,980
02-26-2014, 03:41 PM | #8 |
Rep 32
Manually clearing codes, resetting the DME/ECU, or uninstalling the Cobb just before the OBD II check could all lead to the OBD II check failing. Otherwise, on Stage 1 Maps, you should have no issues... unless, as others have stated, you have DPs and don't have a DP fix!
03-02-2014, 07:21 PM | #10 |
135
Rep 692
I do not believe you can run a COBB Catless Map, even with a DP Fix, because the COBB tune will be cancel out the o2/catless CEL code, preventing o2 readiness from being achieved.
Results > |
03-03-2014, 02:44 PM | #11 | |
11
Rep 209
New to the N5x tuning and I am still figuring this stuff out as well as mapping out my move Last edited by CoolHandLuke; 03-03-2014 at 03:02 PM.. |
03-03-2014, 03:09 PM | #12 |
324
Rep 2,014
The Cobb stage 2 map is made for cars with downpipes.
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
03-03-2014, 03:21 PM | #13 | |
135
Rep 692
What you'll have to do is put on the Stock/Stage 1 or Uninstall the COBB tune with a DP fix, which will not interfere with the o2/catless code and after a little driving will give you emissions readiness. As long as the DP fix is dialed in correctly, you'll be fine.
Results > |
03-04-2014, 09:14 PM | #14 |
7
Rep 267
if i uninstall cobb would my car pass i have catless dp and dp fix???
AFE INTAKE-AMS FMIC-AR CATLESS DP-COBB-HPF EXHAUST
03-04-2014, 09:48 PM | #15 |
135
Rep 692
If the DP fix is set correctly, you should have no problems
Results > |
