ECS boost gauge
02-25-2014, 04:53 PM | #1 |
Rep 64
ECS boost gauge
I just installed the ECS boost gauge. I followed the instructions to a T. Now I am not sure if this is normal or not but it never gets above 0 ever. It sits at idle roughly at 20 vacuum. When I give it throttle it gets close to 0 or a little over. I have called ECS twice asking if this is normal or am I supposed to dial the gauge in or if it comes dialed in. I have checked all the tubes for bends and breaks but they all look fine. Is it possible I didn't hook it up to the correct tubes under the hood? I connected the gauge line to the main line after the T connecting the two diverter valves by the air intake. Has anyone had this problem before? Thank you for any help.
02-25-2014, 05:09 PM | #4 |
Rep 64
Yes. I have driven to the car wash and to get gas. I wasn't flooring it but it is consistently going up and back down. Maybe I should take it in for a boost check. It drives fine. Should it drive awful with no boost?
02-25-2014, 05:15 PM | #5 |
86
Rep 1,262
It would, You would get an underboost code too.. That's really weird.. Where are you hooking the vacuum line up to? What did ECS say?
Josh-
02-25-2014, 05:17 PM | #6 | |
55
Rep 254
Edit can you post a pic of where you connected under the hood? |
02-25-2014, 05:23 PM | #7 |
Rep 64
There are two Diverter valves with two tubes coming off and those two are Y'ed together. Then that's where I put my T after the factory Y. But mine should get above 0 on the boost side right? Or does it take time to make that much boost for the gauge to read it?
02-25-2014, 05:31 PM | #9 | |
55
Rep 254
Edit-the lines look like you connect them correctly |
02-25-2014, 05:38 PM | #10 |
Rep 64
Yeah. The moisture filter is in the dash. I thought that it might be kinked under the dash. I checked one of the lines and there is a lot of vacuum one that line.
02-25-2014, 05:42 PM | #11 |
55
Rep 254
I did not install it on mine, I'm not sure if its a 2 way or one way filter. Maybe
it needs to be flipped to the other side . Don't know if it makes sense? Or try bypassing the filter |
02-25-2014, 05:44 PM | #12 | |
Rep 64
02-25-2014, 05:47 PM | #14 | |
Rep 64
02-25-2014, 05:52 PM | #16 |
Rep 64
02-25-2014, 07:20 PM | #17 |
65
Rep 385
Stand on the thing like you mean it and pay attention to the boost gauge; floor it and stay floored for a while. I have the same gauge, if youre reading ~-20hg at idle seems like it's at least accurate on that end. You could always pull the tube and actually blow on it to test, you should be able to get a couple of psi.
02-26-2014, 05:10 PM | #18 |
Rep 64
I took off the filter and I have seen it go up to 5!! So maybe the filter is the problem or I just didn't give it enough gas to make it work.
02-26-2014, 05:11 PM | #19 | |
Rep 64
02-26-2014, 05:26 PM | #20 |
N54 E92
51
Rep 342
you don't make boost at idle/low rpms
Light Bolt-ons, Tunes, & Methanol Injection: 12.30 @ 115mph [2.0 60ft on Street Tires] [91 Octane] 1.59 Seconds Faster than Stock [as of 05/29/2014] Previous Vehicle: '65 Chevelle [LSx 6.0L/4L80e] |
02-26-2014, 05:28 PM | #21 |
Rep 64
02-26-2014, 05:40 PM | #22 |
77
Rep 2,114
The 20inhg is your vacuum pressure reading in inches of mercury. It should never read 0 unless it's installed incorrectly.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
