BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Intake manifold hell!!!!
      02-24-2014, 06:12 PM   #1
Big Busa
Drives: 15' 335i M Sport Saloon, soon!
I'm hoping someone can give me a little insight on how to proceed. I am about to clean my intakes and change my oil housing gasket. Everything was going along fine until I came to the part about removing the electrical box on the back end of the intake manifold. This thing is about to make me lob a hand grenade under the hood and push her into the street!!! Anyone know a secret to getting this evil little box off of the back of the intake manifold sometime before I'm 50!!! Any help would be greatly appreciated!!!
      02-24-2014, 06:17 PM   #2
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
post a pic to give a better idea. (I do not have a 335 but did drop the intake on my 328)
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      02-24-2014, 06:20 PM   #3
Streetluger06
Drives: 2007 335i coupe
2007 BMW 335i  [0.00]
there is a rubber price that slides over the metal bracket. when I did it I wasted a ton of time undoing those screws on the bottom side of the intake manifold.
if you slide the electrical box toward the front bumper I believe it will slide out. you need to slip a metal tab off of a rubber grommet/hanger. If the front doesn't work try another direction, one will work. I did this two years ago and I'm on my mobile right now so I'm sorry I can't be more helpful.
best of luck.
      02-24-2014, 06:23 PM   #4
Streetluger06
http://www.e90post.com/forums/showthread.php?t=654820
this shows the intake manifold removal. it may help.
      02-24-2014, 06:27 PM   #5
Big Busa
Was using this and a DIY for intake cleaning still no luck!!! Any one got a grenade I can borrow!! LOL!! Any other suggestions before I kill her off?!? Guess I'll keep working at it till it comes off!!
      02-24-2014, 06:30 PM   #6
C.Pop
65
Drives: 335i
You need to put your eyes on the tab that the black box attached to. Once you see how it works, you will understand what is holding it on, and undoing it is just a matter of fiddling with it the right way.
      02-24-2014, 06:34 PM   #7
GetSomeE92
Drives: '09 Space Gray E92
I know exactly what part you're referring to, and I had the same fight you are having when I replaced my low pressure fuel sensor.
First, if you haven't already done so, get a damp paper towel or rag and wipe the box clean. After you do that you will see that the black box has two rectangular "loops" through which it is attached to the bracket under the manifold. The two "prongs" that come out from the bracket and go through these loops are metal. There is a raised section on each which prevents the black box from sliding off easily. I used a screwdriver and pried up on the black loops on the box while pulling one end at a time. Doing this I was able to get that thing off.
I would recommend stepping back, eating something, and coming back with renewed patience. I know I was ready to burn the M-Fer down.
335i Coupe, JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
Skoidat69280.00
      02-24-2014, 06:54 PM   #8
andydna15
Drives: 335i
this video may help.Go to to 8:30 min mark.
      02-24-2014, 07:25 PM   #9
pwr hungry
41
Drives: 335
I couldn't get mine off either. The first time, I just unscrewed all the torx bolts and it took quite a while. This last time, I opened the electrical box and left the top half connected to the manifold and removed it that way. I'll probably fiddle with it some off the car so that next time I can slide it off the clips like it's suposed to work. Good luck and just be patient...it'll come off.
      02-24-2014, 07:39 PM   #10
BMW_drei
BMW_drei's Avatar
Drives: 2013 535i
FWIW...
I sprayed the metal tabs/plastic loops with liquid wrench, then (gently) pryed towards the driver side with a small prybar. Be gentle, and buffer anything you're pressing against. Box slid off easily after getting the plastic hoops past the "bump" on the metal tabs -- depending on how stuck it is, you might be able to do it with bare hands.
2007 335i Sedan / Black Sapphire / Sport / Auto / FBO (Retired)
2013 535i Sedan / Black / MSport / Auto
      02-24-2014, 07:50 PM   #11
Jklad
Jklad's Avatar
Drives: 2007 335i Coupe
I removed the 3 screws, took awhile but it worked. The middle long screw was slow going, but I never replaced it when I put it back together, as some others have also done.
2007 E92 335i MT
      02-24-2014, 07:55 PM   #12
Lifted07Duramax
142
Drives: 2008 BMW red 335i coupe
subbed
JB4 G5, VRSF catless DPs, FMIC, BMS DCI, Muffler Delete, Alpina B3 Flash, RB Turbos, BB Race Flash
      02-24-2014, 08:03 PM   #13
blackbeast06
adrenergic stimulation
blackbeast06's Avatar
45
Drives: 2019 M4cs San Marino Blue
2006 325i  [0.00]
I just did the same job on my car. What I did was slip a flat head screw driver in between the metal tab and the plastic loop that the tab slides into. Working one tab at a time (with a lot of patience) I was able to slide the box so the loop made it over the tab just slightly. One side at a time. I roughed up the plastic loops a little bit but nothing too bad. Before I re-installed the electrical box I used a vise to flatten the metal tabs by squishing the little hump down for easy removal next time. Patience is key here, it was a major PITA.
Here is a thread on taking the intake mani off
Slide a small flat head where the yellow arrow is at in the pic.
[IMG]
electrical box by senntera, on Flickr[/IMG]
2015 M4 Mineral White/Sakhir Orange 6MT
Retired 2007 335i Montego Blue/Saddle Brown 6 MT
Retired 2006 325i Black/Black 6MT
[IMG]m4 by senntera, on Flickr[/IMG]
      02-24-2014, 09:31 PM   #14
buster84
Drives: 2009 335I X-Drive E90
[IMG]
All i did was spray some PB blaster on it and waited. After about 20 mins i came back and it slipped right off with a little force. All you need to do is get the metal to slide out. If PB blaster didn't work for me the next thought was to add some oil to it and use my air compressor to push the oil into the plastic that the tabs are in. Either method should work. Hopefully you get it off, that was the only PITA thing that i had too. I highly suggest PB blaster since it worked for me. Also buy some carb cleaner and use that to clean your intake manifold, throttle body, and intake pipe. I went through two cans but cleaned it all.
2015 BMW M4 F83
2009 335i X-Drive | GC 2.0 Turbos (sold)
2009 335i e93 (Sold)
2007 Bmw X5 (Sold)
      02-24-2014, 10:24 PM   #15
Big Busa
Thanks for the insights. I actually started on valves 1 & 2 to calm down and feel like I am getting something done. I just moved the intake over a bit. I'll try the pb blaster route tomorrow along with the screwdriver. Hopefully both methods together will yeild some results. I'll let you know how it goes.
      02-24-2014, 10:48 PM   #16
cwarren
cwarren's Avatar
82
Drives: 08 e92
2 small flat head screw drivers stuff one on each side and pull the box out don't make it any more difficult than it is . a little muscle to get screw drivers in but that's it .
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
      02-25-2014, 09:39 AM   #17
BoostedE90
BoostedE90's Avatar
Drives: e90 335i 6MT
Remember seeing someone create a tool from a screw driver to remove the wiring box.
EDIT: Found it. Post #7
http://www.e90post.com/forums/showthread.php?t=763958
"The #&^%ing Wiring Harness Junction Box! - I suggest you save yourself a piece of sanity and make this tool. It requires ruining a screwdriver, but believe me - it is worth it. Wedge the tip of the special screwdriver under the plastic slot so that the tip is wedged between the Wiring Harness Junction Box and the metal bracket that is holding it in place. Gently pry up so as to bend the plastic upward so that you can slide the junction box over the metal catch while pulling towards you at the same time. After you get one side, do the same thing to the other. When prying up, be careful not to damage the surface of the intake manifold where the throttle body mounts - you need that surface to stay nice and smooth so that the throttle body o-ring seals."
      02-26-2014, 08:49 AM   #18
Tzu
29
Drives: 335i
Remove throttle body and you'll have full visual access to the electrical box.
      02-28-2014, 10:53 AM   #19
bimmertt
bimmertt's Avatar
93
Drives: 2007 e92 335i
I spent a lot of time trying to get it out by hand..ended up doing the same thing with one of my many screw drivers and got it out in a minute...
      03-01-2014, 02:19 AM   #20
subbie79
Drives: 2007 335i Sedan
As mentioned in previous posts, there are two tabs.
What i did was i placed a flat tip screwdriver on the tab and hit it with a mallet. Rubber piece will slide off. I find that's the easiest solution, and the quickest.
      03-01-2014, 02:29 AM   #21
Sfvalley135i
53
Drives: 135i
wtf !
I just removed my intake manifold, I was all prepared to struggle with the electrical box...
Once I got to it, the damn box slid off without any trouble or force!
      03-01-2014, 01:27 PM   #22
Big Busa
Originally Posted by Sfvalley135i View Post
wtf !
Fortunate!! Very! Well, I finally got the box off and finished everything. Putting her back together now. Will let you know my thought as soon as I can.
