Battery Question
02-20-2014, 04:33 PM | #1 |
43
Rep 420
Battery Question
Hi i need some help with battery replacement. My car is 07 335i (e90) and still has oem battery (90ah) and its time for a new battery. so i was thinking about duralast battery but i couldn't find ah on them and i also found some battery from (http://www.ntb.com/tires/Shop-Batteries.j) which shows ah 72ah 80ah and 100ah. is it ok to change battery ah from 90ah to 100ah or 90ah to 80ah?
02-20-2014, 05:01 PM | #2 |
51
Rep 1,061
While the vehicle can work with a smaller battery, you'll have less reserve as it gets colder (batteries lose a lot of cranking power when it gets cold), or as it ages. Bigger, if it fits, isn't a problem. But, if your vehicle is like the newer ones, you need to also have the dealer reprogram the computer so it knows the size and type of battery that is now installed...the computer adjusts the charging/max discharge scheme based on both the size, type, and age of the installed battery so it's not just throw a new one in...the computer will treat it more gently since it thinks it's an old one on its last legs, rather than a new one.
02-20-2014, 05:49 PM | #3 | |
503
11
Rep 159
02-20-2014, 07:24 PM | #4 | |
Rep 153
02-20-2014, 08:06 PM | #5 |
51
Rep 1,061
I do not know when BMW started to use AGM batteries in their cars, but if you have an AGM, I highly suggest that you replace it with an AGM. IF the software does not offer that as an option, you should not, since an AGM needs higher voltage to become fully charged than other types generally available.
02-20-2014, 08:49 PM | #7 |
41
Rep 557
I just replaced my 07 335i E92 battery. I had the original battery in my car too, which was the white (FLA) one. You should replace yours with an FLA if yours is white, otherwise you'll have to get it re-coded in addition to getting it registered if you go to an AGM battery. Check out my thread for the one I used:
http://www.e90post.com/forums/showthread.php?t=931443 |
02-20-2014, 09:15 PM | #8 |
72
Rep 751
Drives: 08 E90 335i JB
Just got a Duralast H8-AGM for my '08 e90 today. It's exactly the same size as oem. And it's AGM 90 AH, same as the original one. So the only thing I need to do after the installation is to register it with BMWLogger software.
08 E90 335i Jet Black/Black/Piano Black Step/PS ZSP ZPP PDC CA
KW V2/AG M550/ACS roof/Pedals/CF Roundels/M3 rep bumper/Lux 5.0/Yellow fogs/Alpina B3/JB4 G5/VRSF FMIC/ER CP/Tial BOV/Muffler Delete |
02-20-2014, 10:14 PM | #9 | |
43
Rep 420
I saw duralast agm for about 170 with 92ah |
02-20-2014, 10:44 PM | #10 |
BMWCCA 149159
38
Rep 847
My E93 had a 100AH white AGM battery. Key is if it is sealed or not. Sealed is AGM typically. If you have the right K+CAN cable you can register your battery yourself by visiting a thread in this forum by smooth. He has a free software that allows you to register your battery. I have used it and it works just fine.
Good advice to stay with the same AH and type (lead-acid vs absorbed glass mat (AGM)... |
02-20-2014, 11:35 PM | #11 |
93
Rep 1,644
I just went to auto zone told them I need a battery and the best and most expensive one for my car through it in and called it a day. No coding no programming. No problems its been 2 months.
02-20-2014, 11:40 PM | #12 | |
681
Rep 3,696
02-21-2014, 02:26 AM | #13 | |
851
Rep 2,793
I thought bmws battery needs to be coded to the car......can someone explain this If someone buys a oem battery does that need to be coded or not.....or just different spec'd or brands need to be coded?? : |
02-21-2014, 03:09 AM | #14 |
43
Rep 420
Ya i did check az web and most of the battery don't provide ah.....
02-21-2014, 06:21 AM | #15 |
41
Rep 557
They need to be REGISTERED, not coded if you buy an FLA to replace an FLA, or an AGM to replace an AGM. If you don't register it, the battery will still work but your car is not going to know that a new battery is in and will not take advantage of the capabilities of a new battery versus your old worn-out one.
02-21-2014, 06:41 AM | #16 | |
295
Rep 2,202
For a switch from a FLA (White casing) to an AGM (black) it is customary to have the car coded properly.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
02-21-2014, 09:08 AM | #17 | |
72
Rep 751
Yes, I paid $169.99 for the Duralast.
KW V2/AG M550/ACS roof/Pedals/CF Roundels/M3 rep bumper/Lux 5.0/Yellow fogs/Alpina B3/JB4 G5/VRSF FMIC/ER CP/Tial BOV/Muffler Delete Last edited by JacobT; 02-21-2014 at 10:07 AM.. |
02-22-2014, 08:44 AM | #18 |
8355
Rep 2,963
Bought an AutoCraft Gold Battery, 49H8 at Advanced Auto Parts. Seems to be working perfectly. Also had it registered at a local Indy for $45. Battery was $110 - bought it online with store pick up using a 30% off coupon code. I think it was TRT30.
02-24-2014, 10:46 PM | #19 | |
681
Rep 3,696
Formula for calculating AH AH = (RC / 2) + 16 My car is coded for a 90AH charging profile and my original bmw battery has an RC of 160. Using the formula above i get the following: (160 / 2) = 80 + 16 = 96 AH (so the car being set at a 90AH profile makes more sense to use rather than the 80AH profile or the 110AH profile). Makes sense?? |
02-27-2014, 04:13 PM | #21 | |
43
Rep 420
02-27-2014, 04:31 PM | #22 |
Fuck it dude, let's go bowling.
888
Rep 2,480
I went to the dealer yesterday and bought an OEM replacement battery - $179. Register and done, no coding, no worries.
1M. Previously: '13 135is; '07 E90 335i; '02 325i; '99 Z3; '98 328is; '87 L6; '77 320i
