Bearing ledge DIY in the making.
02-20-2014, 01:28 PM | #2 |
456
Rep 6,478
Thanks, think this will become increasingly useful as motors continue aging. Cam ledges aren’t a typical “issue” here but it’s also not something that has been given a ton of thought.
Would just say it’s going to be so much easier with the BMW specific tool.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
02-20-2014, 02:43 PM | #3 |
132
Rep 573
I'm at 100k but from what i researched it happens as low as 20k on n54's.
I migh just bite the bullet its only $60 to rent the tool plus $300 deposit but i wanted to do this weekend. Thanks for the input. |
02-20-2014, 02:57 PM | #4 |
22
Rep 257
The local mechanic I take my car to mentioned this becoming an issue on some 335i. The conversation took place a couple months ago (and I could be wrong on this) but he said it seems to be from cars that havent had their oil changed frequently (every 4k miles) as BMW recommends every 15k miles and thus on some engines the right cam shaft (nose side) getting starved of oil and peeling into the ledge and ledge pieces blocking pathway for oil.
Sound right? Sorry I am not the most mechanically inclined when it comes to engine internals and I have shitty memory. |
02-20-2014, 08:44 PM | #5 |
11
Rep 368
I'm willing to bet you sucked part of your accessory belt into the oil pan when it let go. This is common if the belt lets go while the motor is running. The belt pushes it's way past the front main seal and shards and pieces of it go into the oil pan. It's blocking your oil pickup tube and probably imbedded particles into your rod bearings and clogged the VANOS solenoids to the point it throws codes. This would explains the low oil pressure light on startup and the VANOS codes as well. Sorry about your luck man.
http://www.e90post.com/forums/showthread.php?t=768753 |
02-20-2014, 09:31 PM | #6 |
82
Rep 725
^ +1 pull the valve cover and see if there is anything in there . this could really turn bad quickly
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
02-20-2014, 09:57 PM | #7 |
41
Rep 1,257
I've read of the belt issue as well. Maybe throw the oil pan gasket on your first thing to do list. If you see belt bits in the pan, you know you have some serious work ahead of you. Good luck and report back!
02-20-2014, 10:06 PM | #8 |
132
Rep 573
very possible I did read that the belt could rip your front main seal but if so i would be leaking from my main seal which i check and the only leak i have is from the VC gasket to the top of the Catalytic converter.
i can see the belt chewing up the main seal but going past it? but who know's lets hope i'm right. I did drain the oil after replacing the vanos and just oil came out no chunks or strings of the belt came out. Now before i have anymore nightmares wouldn't i have the low pressure light all the time? Mine comes on for a few seconds only on cold starts. I ended renting the tool to hold the cams just in case i run into any problems. Thanks for the input i'll pop the VC off and hope for the best. |
02-21-2014, 06:17 AM | #9 | |
41
Rep 1,257
02-21-2014, 06:40 AM | #10 |
Guest
Rep n/a
Drives:
Best of luck! Looking forward to seeing your progress.
Dumb question and somewhat off topic but: I never understood why chains/belts had to be secured to cam gears when swapping cams, cam gears, etc. I know it's different on this platform given VANOS and various other N54 uniqueness, but on 2JZs, 4G63s, etc. the installs always show this (zip ties on the cam gears/belt if the gears themselves aren't being changed). Theoretically, if you bring the motor to TDC, line the gears up with the appropriate notches on the belt cover, etc. then what's the point of marking the belt or securing the gears to begin with? What were to happen if the gears AND cams AND chains needed to be replaced? I doubt people break out a degree wheel at that point, especially when the motor is still in the car. As long as the key on the cam gears fits into the cams correctly and everything matches up with the stock timing notches after the fact, isn't that about as good as the timing will get anyway? Sorry for the n00b question, I'm just trying to visualize it from an automotive standpoint in general. |
02-21-2014, 09:44 AM | #11 | |
11
Rep 368
Back in high school I made the mistake once of putting too much RTV on the oil pan after installing the drain tube for a turbo kit. The RTV ballooned out when mating to the engine block and some pieces broke off and fell into the oil pan, which eventually lead to them getting jammed into the screen on the oil pump suction tube. Wanna guess what my symptoms were? Low oil pressure light on cold starts... Take it for what its worth. Best of luck to you. |
02-21-2014, 04:19 PM | #12 |
king of the hills
92
Rep 2,915
Drives: 2011 M3 w/ESS55, 2001 540i/6
OP, what date build is your car? The cam bearing ledges were really only an issue with the early build 335's, they revised the part after about middle of 2007 iirc.
02-21-2014, 07:04 PM | #13 | |
132
Rep 573
I still have the oil i drained no belt residue so i'm hoping for the best. I'm taking the vc tom which i have to either way its leaking from there. |
02-21-2014, 07:06 PM | #14 | |
132
Rep 573
03-10-2014, 12:14 AM | #15 |
SW20 to BL to E92
35
Rep 179
03-11-2014, 06:02 PM | #16 | |
453
Rep 2,973
Recently I went in for an O2 sensor fault and I complained of rough idle. The SA called me to tell me they were pulling the top end apart. They looked at the intake and it had buildup but also valve seals leaking. Once they got it apart to do the seals, guess what?? Cam bearing ledges, intake and exhaust scored. Final bill came to $2100 in parts. I have no idea what the labor was. It was all done under CPO. I'm guessing, that the BMW interval for main't is tooooooo long. Should be under 10K miles like 2014 cars. YMMV but, after this I'll be switching to a 5-7.5K service interval. I'm also switching from the 0w30 that BMW recommends and switching to Amsoil 5w40 Euroblend that I use in my other cars. I run Amsoil in everything else and have never had an issue. BTW - my car has 95K on the odometer so the bearing ledges were replaced 72K miles ago.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
03-13-2014, 04:02 PM | #17 |
king of the hills
92
Rep 2,915
Well that sucks, but good to know.
