coolant leak from bottom of crank pulley
02-20-2014, 10:27 AM | #1 |
12
Rep 102
Hi everyone, i just did a partial coolant drain and bleed the coolant and found a leak coming from the bottom of the crank pulley, can't see any leaks coming from the top area, drips sort of heavy during the bleeding procedure, any ideas from where it can be coming from? thanks for the help
02-20-2014, 10:50 AM | #2 |
41
Rep 1,257
Are you seeing it on the frame rail under the pulley? Check the diagram in the link. It has the hoses that run in that area.
http://realoem.com/bmw/showparts.do?...05&hg=17&fg=30 |
02-20-2014, 09:49 PM | #3 |
82
Rep 725
#8 o ring leaked on my car after I changed OFHG could be leaking from there down on crank area . good thing if that's what it is its cheap and easy to replace.
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
02-21-2014, 10:22 AM | #4 |
12
Rep 102
Thanks for the help guys, it was a hose connecting to the engine that i had to remove to access the bottom bolt on the off on the left side, replaced the o-ring and seems to be doing fine now.
02-21-2014, 10:58 AM | #5 |
208
Rep 1,161
I was going to say...
If you were leaking coolant from your crank pulley, something very unusual and very expensive was happening. Glad you got it fixed. |
