Leaking charge hoses
02-19-2014, 12:09 PM | #1 |
Warrant Officer
375
Rep 1,341
So I took my CPO'd car into the dealership because I noticed my red charge pipe was leaking oil recently. I got a phone call today from the SA saying both of them were leaking (opposite ends from the intercooler) and this isn't covered under warrantee. He was blaming this under my accident I had. This problem started not too long ago, so it's definitely not accident related (both parts are bent apparently).
$1500 for the repair. Obviously I won't pay for that because it's a warrantee repair. Should I contact BMW NA about this?
Deleted, ATM I/C and tuned by B.R.R.
02-19-2014, 12:28 PM | #2 |
157
Rep 716
Leakage at boost charge pipe look like a common problem. If you decide to fix the problem yourself. See:
http://www.forgemotorsport.co.uk/con...oduct=FMBH335D http://www.bimmerfest.com/forums/sho...d.php?t=753755 |
02-19-2014, 01:10 PM | #3 |
Warrant Officer
375
Rep 1,341
Even told them it's a common problem. Did not change their mind. I usually have great experience with this dealership but the past 2 visits haven't been.
02-20-2014, 12:12 AM | #4 |
671
Rep 1,442
Total BS not to cover the charge hoses. This is a common problem and my 2010 CPO has been in three times for this repair. These hoses do not tolerate heat well and fail frequently. This has a subtle but meaningful impact on performance and MPG. This is a well documented problem. How can the dealership be so stupid!?
02-20-2014, 08:53 AM | #5 |
Warrant Officer
375
Rep 1,341
Yep it is.
I'm just going to try and find replacement hoses then. I can get the Forge hose for about $100, as what Montr showed me. I just need to find the intake side aftermarket replacement.
02-20-2014, 09:15 AM | #6 |
Rep 50
I understand that the charge leak lets oil and air out of the charge system. This increases boost time and decreases boost pressure. But once the leak is sealed doesn't all the oil that would normally leak out just accumulate in the bottom of the inter-cooler? If so, how hard is it to clean, and more importantly dry, the inter-cooler before re-installation? I assume you can draw air through it for a couple hours with a shop vac to dry it.
Thoughts? Cheers |
02-20-2014, 09:50 AM | #7 |
157
Rep 716
That is correct. The oil fume and vapor condensate at the bottom of intercooler, like a catch can. The oil come from the crankcase ventilation system (PCV valve) and the turbo oil seal.
In a previous car, Volvo inline 5 Turbo, the intercooler had a small hole (~1/16" diameter) at the bottom. This way, there is no accumulation of oil or water in the intercooler. It is blown away when there is pressure boost. The drawback is that the car was leaving occasionally few drop of oil in the garage floor. When the car was new, I was concerned about the oil leak. Eventually, I learned to live with it, I put a cardboard on the floor under the intercooler. |
02-20-2014, 10:17 AM | #8 |
Rep 50
A small hole. Makes sense. I assume then that our D intercoolers are sealed up tight and that water and oil accumulate over time making the intercooler less efficient. Eventually something must give. Where does our water/oil puddle go?
Thoughts on need for intercooler cleaning? Cheers |
02-20-2014, 12:20 PM | #9 | |
157
Rep 716
I am also thinking removing the intake manifold to inspect and clean for carbon buildup. I bought a set of brush last week at Harbor Freight for that purpose. Instruction call for new seals when replacing the intake manifold. I am now debating if I need to order the gasket or not. On this post (5 series), the OP reused the seals. Procedure look more time consuming, 5 hours? http://forums.5series.net/diy-do-you...-engine-53457/ |
02-20-2014, 04:45 PM | #10 | |
671
Rep 1,442
http://www.e90post.com/forums/showth...ight=oil+smell |
02-20-2014, 06:35 PM | #11 |
Warrant Officer
375
Rep 1,341
I went and visually checked the intake side hose, and I found no such bends or any signs of oil leaks. The turbo side, or red charge pipe, had signs of leakage though. This pisses me off. It's one thing to blame an accident, but it is another to say a part is broken when it appears to be not.
I'm going to check the under side tomorrow just to verify this.
