Oil schedule for super low mile N54
02-16-2014, 11:18 AM | #1 |
378
Rep 2,067
I would like to get some advice regarding how often I should change the oil on my N54. I am the first owner of the car purchased March 1, 2009. I have only averaged 5,000 miles per year as the car is about to hit 25,000 miles. Since I plan to keep this car for a very long time I have been doing oil changes every 6 months (1 free and 1 out of pocket). However, now that my car has been out of warranty I am reconsidering whether it makes sense for me to pay for two oil changes per year.
My last oil change was 8/8/13 and I had 22,945 miles on the car. As of today I have just under 25,000 miles. I do have a coupon to get my oil changed at the dealer for a very reasonable price so I am inclined to change the oil. Do you think it would be a complete waste? When I drive the car it is unfortunately usually for short commutes and lots of stop and go traffic. I also have been tuned for the past 1.5 years. Any advice would be appreciated on how often you would change the oil on an N54 that only gets driven about 5k per year. Also should I look into changing my transmission/diff oil and/or spark plugs? Any must change items on a 5 year old car but one with only 25k miles? Thank you!
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB |
02-17-2014, 05:45 PM | #2 |
30
Rep 452
Change the plugs every 20k (seems too often but tuned cars require this and they are cheap). I change the oil every 6-7k miles using 0-40w mobile one synthetic (ditch the crappy oem oil). Or in your case change the oil every year. Most people will say to change the tranny oil every 50-60k if you plan on keeping the car, there is a lot of debate on this topic google search is your best friend. I used redline ATF. The same goes for the differential oil.
GIAC, Alpina TCU Flash, Ohlins, Brembo, Eisenmann, Quaife, Evolution Racewerks, Wagner Tuning, AFE, M3 suspension bits
02-17-2014, 06:31 PM | #3 |
3441
Rep 79,211
Change the oil every year or every 7500 miles. Whichever comes first. Only other way to judge your oil interval is to get an oil analysis done on the oil. That will then tell you approximately how much longer or sooner you should have got the oil changed.
02-17-2014, 06:31 PM | #4 |
127
Rep 865
Drives: BMW X3 35i, Porsche Macan S
If you change your oil once a year and your plugs every 10K miles (with a tune) you'll be good. You have many more years before you need to worry about transmission or differential maintenance.
I had the same questions since my 2007 335 only has 18K miles. This is the maintenance schedule I follow.
MOTIV 750 ST | MOTIV PI | 100% E85 | Fuel-it Stage 4 LPFP | MOTIV Boost Box + MHD Protune | Quaife | Öhlins | Brembo | Akrapovic
02-18-2014, 08:06 AM | #6 |
59
Rep 886
what about injectors??? How often they should be changed???
What are the symptoms of bad injector???
Bmw 335xi/FBO/ black on black/ 6sp manual/Cobb AP/BMS DCI/AA BOV KIT/VRSF DP'S/VRSF 7'FMIC /FULLY CATLESS/H&R sport springs/ 19' ac schnitzer wheels.
02-19-2014, 08:57 AM | #7 | |
59
Rep 886
02-19-2014, 04:30 PM | #8 |
133
Rep 4,764
Wow, that's low miles. I'm at 22,000 miles on my RB Turbo 4/2007 build. I change my oil every spring and fall. May be a little overkill, but not too bad. Since the car is tuned, changed plugs at 13,000 miles and they needed it. Will probably change them again this spring.
02-19-2014, 07:18 PM | #9 |
2050
Rep 6,110
Man, some seriously low mile cars in here. I am at 115k and loving it. However, I have changed driving habits and only put about 3k miles on the car a year now. So, I've switched to time-based maintenance. It sounds like OP should be doing the same.
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
08-03-2014, 04:50 PM | #11 |
10
Rep 111
I don't put a lot of miles on my car but when I drive it I drive it pretty hard and because of that I feel there is absolutely zero reason to change ur oil every 7500 miles or ,ore condsering in that span ur probably topping off with at least 2 quarts I change every 4 thousand it's pretty cheap doing urself probably 60 bucks for peace of mind that I'm taking care of my engine and my oil is def gross after those 4k
