first log
02-15-2014, 07:13 PM | #1 |
30
Rep 780
first log
ok first log.. here is is any help would be great temp outside was 39 degrees in denver had half of tank filled it a few days agot with 5 gal of e85 rest shell 91.
thanks in advance http://www.datazap.me/u/chepy24/log-...=0&data=1-8-20 looks terrible to me :-/ edit:mods are only cobb v2 on stage 1 aggressive and dci......also went with standard log list any recommendation on what i should be logging? Last edited by chepy24; 02-15-2014 at 07:53 PM.. |
02-15-2014, 07:41 PM | #2 |
27
Rep 388
Boost is way off target. Start by listing your mods so people can help you troubleshoot.
335 XI Coupe/ RB Turbos/ JB4 w/ Wedge Backend / Meth / Inline LPFP / E85 / UUC SSK / Spec2+ SMFW / HPF 7'' IC / Forged DV's / AR DP's / BMS DCI / Apex Arc-8 /Hankook Ventus V12 EVO / KWV1 / HPF Exhaust/ NGK/
02-15-2014, 07:45 PM | #3 |
30
Rep 780
02-15-2014, 07:57 PM | #4 |
34
Rep 288
It doesn't look too bad. Your main issue is up to 4K rpm. In real life you are never going to be using that.
Logging list is fine. Next time continue logging all the way into 4th gear. If you want to fix the boost oscillation up to 4Krpm, lower D-Factor multiplier from on 3K rpm to 4k rpm. Don't worry about hitting target at red line, as is your boost looks safe for your mods.
Cobb / DCI / VRSF Downpipes / VRSF 7" Intercooler / Walbro LPFP / E85
02-15-2014, 07:59 PM | #5 |
27
Rep 388
What Cobb map are you on?
02-15-2014, 09:17 PM | #7 |
27
Rep 388
Talking to OP
