Throw out bearing stuck!
02-15-2014, 12:59 PM | #1 |
34
Rep 632
My car is over at Cobb Plano getting a spec 2+ installed and they called me telling me that the stock throw out bearing is stuck... Anyone have any experience with a stuck throw out bearing? If so, what did you do or what was done?
2007 335i e90 6mt | Motiv 750 XR8267 | RB PCV | JB4 G5 | MHD Pump Flash | Walbro 255lph | VRSF CP & Tial BOV | NGK Plugs | Custom Side Exhaust | CxRacing FMIC | Spec 2+ & SSMFW | StopTech Drilled/Slotted Rotors | Hawk Performance Pads | DEFIV Lockdown kit | Mtec V3 | Apex PS7s | 35/15% Llumar ceramic
02-15-2014, 04:09 PM | #2 |
11
Rep 399
yes.. mine was stuck too. They had to get a chisel and carefully cut it apart piece by piece. Its not fun.
JB4 G5 ISO W/BMS FLASH, FBO, Walbro LPFP, Spec S2+ SMFW
02-15-2014, 05:37 PM | #3 |
34
Rep 632
I got an update that it's the pilot bearing that is stuck and not the throw out bearing.... either way my car isn't and won't be ready...
02-15-2014, 06:58 PM | #4 |
0000000
12
Rep 144
Throw out or even pilot bearing being stuck sounds weird. Do they have the trans out to even see it? At that point, it's cheaper to replace the whole clutch, pressure plate, and all the bearings (which come in the kit) as well as the fly wheel than it is to replace whatever bearing is screwed and put it back together.
Idunno. I trust cobb, but that sounds really weird. I'm guessing they're saying the car is stuck in gear, right? |
02-15-2014, 08:36 PM | #6 | |
34
Rep 632
02-16-2014, 09:57 AM | #8 |
82
Rep 725
dont think I have heard of anyone being able to get these out easily this really does require a special puller with a very fine grab to it . you would think cobb would of had the tool as this couldn't have been there first pilot bearing on a bmw
ptf MHD E85 /Hexon rr550 turbo's/PRE custom intakes/CP / bms dp's/hfs4 / er fmic/PSS/spec stage 2+/kwv2/steveAZ stage 3 lpfp /m3 control arms/powerflex black/MF LSD /fuel it port injection
02-16-2014, 11:09 AM | #9 |
65
Rep 1,708
BMW should have a specific tool. One member, GeorgiaTech, used a harbor frieght slide hammer kit successfully after trying various other methods.
02-16-2014, 02:44 PM | #10 | |
0000000
12
Rep 144
yeah, mine was a pain getting out. We had to use a slide hammer and be pretty unkind to it, the bearing, the inputshaft, and anyone within an earshot. It took a few hours, but the slide hammer did the trick for me. The grease-gun method wasn't getting me anywhere but...sticky. Good luck, man. Get some pics if you can. In the end, this will just be a good story. |
02-16-2014, 02:50 PM | #11 | |
0000000
12
Rep 144
The trick was to use the slide hammer attachment with the teeth that rotate outward as you screw it onto the slide hammer's shaft. It's too wide on their own to just slide in to the PB, so we had to use a punch to get one of the pins of the fingers out, slide the remaining attached tooth/finger into the PB (a friend is handy here since the hammer itself isn't exactly light), slide the removed finger in, pop the pin back in, then spread the fingers. In the end, it's a really crappy mechanical connection to the PB and it'll slide away from the PB with every hit of the hammer, but in doing so, the PB itself will come out a little. We trashed the inside of the PB, but it did come out far enough to grab it and pull with vise grips. |
02-16-2014, 04:26 PM | #12 |
34
Rep 632
It's at least good to know I'm not the only one! Yeah they have a guy from Snap-On bringing them some special tool on Tuesday so hopefully I get my car back then... Damn glad I didn't try this install myself lol
