which brand and grade synthetic motor oil does the 335 use?
11-09-2007, 10:27 PM | #1 |
83
Rep 793
looking to do an oil change soon... and want to do it before the BMW free change
Now: '11 BMW X5 xDrive35i
Then: '07 X3 3.0si '07 335xi '06 Audi A4 2.0T Quattro |
11-09-2007, 10:48 PM | #2 |
29
Rep 1,002
almost all turbo cars typically use any standard fully synthetic 5w-30... 10w-30 is a little safer, especially for cold starts. mobil 1 burns pretty fast. royal purple is pretty good, as well as the standard BMW branded synthetic made by castrol. but i always use motul.... except for on the M Coupe since it calls for the Castrol TWS Motorsport 10W-60... and the only other brand i know that makes a 10W-60 is a japanese brand called fusion and its like insanely expensive.
11-10-2007, 09:26 AM | #3 |
111
Rep 1,772
335i will call for any synthetic oil with the BMWLL01 or BMWLL04 rating.
Examples are: - BMW High Performance Synthetic 5W30 - Castrol Syntec 0W30 (not 5W30 in North America!) - Mobil1 0W40 - Amsoil European Formula 5W40 |
11-10-2007, 10:01 AM | #4 | |
DVM
Rep 77
Mobil1 0W40
Very hoppy 335 with Mobil 1 0-40W.
11-10-2007, 11:16 AM | #5 |
83
Rep 793
Thanks guys... I'll most likely go with one of these...
- Castrol Syntec 0W30 - Mobil1 0W40 will these be ok for cold winter starts in NY?
11-10-2007, 02:30 PM | #6 |
Rep 151
Absolutey. The lower the first number, the easier it pumps through the lines while cold. Very good stuff. My personal preference is Mobil1 as I have no experience with Castrol.
11-10-2007, 05:09 PM | #7 | |
111
Rep 1,772
I was running Mobil1 0W40 last winter and had a number of -30 degrees celius starts with no problems. I am now running the Syntec 0W30 and my car seems to like it... haven't had any really cold starts yet this year. Both have very cold pour points (like -52 degrees Celsius for the Mobil and something like -48 Celsius for the Castrol). Both are top notch products from my experience with each... the car does seem to get slightly better fuel economy with the Castrol Syntec, I should mention. |
11-10-2007, 05:46 PM | #8 |
Moderator
133
Rep 6,775
Drives: TiAg E92 335
I run Mobil1 in all of my cars. In the 335i I run Mobil1 0w40.
-Michael.
Berlina Black S2000 CR is now in the garage l 19" Rial Daytona Race l KW V2 l Eisenhaus Race Exhaust l |
11-10-2007, 06:48 PM | #10 |
29
Rep 1,002
11-10-2007, 06:49 PM | #11 |
83
Rep 793
wow 7 quarts... thats a lot My 5.0 Liter mustang used 5 quarts.... granted it didnt have a turbo system that probably needs to be lubricated
11-10-2007, 06:55 PM | #12 |
29
Rep 1,002
really? my S2000 was 5.5 and my 330ci was right at 6 if i remember correctly... i just did a quick search on google and came up with that. that seems like a lot but i wouldn't be surprised since high revving cars and turbo cars tend to burn oil easily, and to add fuel to the fire, i think you could safely consider the 335i a relatively high revving turbo.... 7 quarts wouldn't surprise me at all... the easiest way to find out is to look in your manual. i'd bet you an oil change it's in there.
11-10-2007, 07:27 PM | #14 | |
103
Rep 1,417
I have used Mobil1 for years, however when I read the specs. For the 335i it sounds like the only Mobil1 product that will do is the 0w40. Red
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
11-10-2007, 07:35 PM | #15 |
32
Rep 1,786
Just buy whats recommended by BMW for the car. Buy the oil and filter from your dealer and your good to go. My last 2 cars were turbos and i used what the manufacturer recommended,Mobil 1 10w30 for all year around use. When i do my first oil change i will get the oil and filter from the dealer,(BMW).
11-11-2007, 10:19 AM | #16 | |
111
Rep 1,772
On the other hand, Castrol Syntec 0W30 sold in North America is BMWLL01 approved. Mobil1 0W40 is also BMWLL01 approved (5W30 Mobil1 is not BMWLL01, nor is 10W30). |
11-11-2007, 11:52 AM | #17 |
29
Rep 1,002
I just found out there is a Motul that meets BMW specs, it's a 5w-30. ideally, i would use that... http://www.hmsmotorsport.com/store/f...motul-spec-oil
11-11-2007, 07:47 PM | #18 | |
118
Rep 3,432
11-11-2007, 07:51 PM | #19 |
95
Rep 2,573
Drives: AW DCT M3
All the dealerships (At least around here) say Castrol SYNTEC 5w30 Full Synthetic is the exact oil they use except theirs is package BMW... It's what i use when I do mine. in the US that is if it matters
