Where does my checkvalve go? pwm methanol kit
02-14-2014, 09:32 PM | #1 |
N54 E92
51
Rep 342
I'm almost done installing my trunk mount pwm vishnu meth kit. I picked up from a user on this board and it came with a check valve like this:
where should it go? i know it goes after the pump... but in the engine bay close to the fav or in the trunk just after the pump. Also have my nylon line/wire routing to the amplifier area. how do i run it to the tool area located under the lift-up lid? any tips? thanks everyone
Light Bolt-ons, Tunes, & Methanol Injection: 12.30 @ 115mph [2.0 60ft on Street Tires] [91 Octane] 1.59 Seconds Faster than Stock [as of 05/29/2014] Previous Vehicle: '65 Chevelle [LSx 6.0L/4L80e] |
02-15-2014, 08:11 AM | #2 |
261
Rep 1,093
Both snow and devils own recommend it being installed between the tank and the pump
page 5 under caution http://www.snowperformance.net/produ...tion_pdf-8.pdf page 4 http://www.alcohol-injection.com/en/...r-1-directions However many an enthusiast like to put it reasonably close to the nozzle where there is less fluid in the line after the check valve to make its way into the engine. |
