Internal Coolant Leak?
02-13-2014, 08:27 PM | #1 |
Rep 24
So the Dealer just fixed my oil filter housing gasket(oil leak), cracked cylinder head cover (supposedly oil leak as well) , and replaced all 4 o2 sensors.
I also had a coolant leak which the dealer didn't look at. Are these all related? I read somewhere that an internal coolant leak can cause the cracked cylinder and contaminate the oxygen sensors. Or can it be the other way around? So if those were repaired except the coolant leak. Will the coolant leak continue? And possibly re do the damage or is the repairs going to self fix the coolant leak |
02-13-2014, 08:46 PM | #2 | |
Stupid Idiot
134
Rep 827
02 sensors typically have a 100k mile service interval. Depending on your mileage, they may have recommended doing all 4 based on that. I'm guessing you had some type of issue that made them go that direction, correct?
02-13-2014, 09:01 PM | #3 | |
Rep 24
I don't think I've seen coolant on the ground, just when the light came on and I checked it was missing a lot already. I was only getting oil onto the ground My car only has 60k miles, and I was getting the service engine light + constant misfires on one occasion only. The day before I took it in. Next day it was fine |
02-14-2014, 09:24 AM | #4 | |
Stupid Idiot
134
Rep 827
Just because you don't see coolant on the ground doesn't mean you don't have a leak. There are panels that cover the underside of the car and prevent a lot of it from reaching the ground. Internal coolant loss is very rare on this engine. Not saying it isn't possible, just rare. I've seen the oil filter housing gasket allow coolant and oil to mix. Maybe that was the scenario on your car. Were these repairs done under warranty?
02-17-2014, 05:20 AM | #5 | ||
Rep 24
02-17-2014, 08:55 AM | #6 |
Down with the N54.
16
Rep 409
If the oil filter housing was replaced, expect the water pump to fail shortly! That gasket hardens up and breaks apart, and does a real number to the plastic housing and impeller of the water pump. Happened to me! Don't plan any road trips!
02-17-2014, 05:03 PM | #7 |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
WOW,
I hope you had CPO. That was probably a huge bill.. |
02-17-2014, 05:35 PM | #8 |
21
Rep 72
If you have a chance, check the temp sensor located at the coolant hose just to the left of the radiator fan (passenger side). The o-ring wears off and cause a small leak, that's what happened to me.
02-17-2014, 05:56 PM | #9 |
Rep 212
I had a hairline crack in the coolant reservoir that only leaked when the car was really hot . . pressure check your coolant system as recommended above.
