335i LPFP
02-12-2014, 02:10 PM | #1 |
50
Rep 405
335i LPFP
I did some searching but wanted to ask the more experienced guys a question on the 335i LPFP. I was getting some mixture control codes 2e90 and 2e91 and occasional P2aaf with SES light when running cobb E30 or 3 gal of E85 to 13 of 91 ACN on cobb stage 2+fmic aggressive . Long story short I changed the pre cat o2 sensors and my LPFP sensor and codes are gone. My question is while doing logs running 3 of E85 with 13 of 91 my LPFP is getting as low 50psi. Ive heard 50 is the magic number that can cause problems. I don't know the range the pump should operate in new. should it ever drop below 72psi? should I just get a new one is this one on the way out? My car is FBO with 60k on it.
thanks guys Last edited by loweredram; 02-12-2014 at 02:11 PM.. Reason: left out some info |
02-12-2014, 02:16 PM | #2 | |
34
Rep 288
Cobb / DCI / VRSF Downpipes / VRSF 7" Intercooler / Walbro LPFP / E85
02-12-2014, 02:26 PM | #3 |
456
Rep 6,478
Stock pump is likely getting tired at that mileage as well. I just replaced the entire bucket when I added the FFTEC pump.
Generally speaking you don't want to see pressure fall below 50PSI or it drags the high pressure side down with it.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
02-12-2014, 08:12 PM | #4 |
88
Rep 1,039
My original pump at 50k miles would drop to 42psi on 93 oct.
Replaced with a new lpfp and rocking 78psi all day. Time for the replacement. I had all the exact codes and issues you are experiencing. All problems fixed!!! And I'm Fbo also. So literally we have had the same issues. Hope this helps. |
02-12-2014, 08:30 PM | #5 | |
50
Rep 405
I luckily found a place selling the OEM pump (VDO) complete on sale for the next 3 days for $211.00. I've read a few diy on removing and replacing the pump doesn't look to complicated. Thanks again!! |
02-12-2014, 10:48 PM | #7 |
50
Rep 405
[QUOTE=FCobra94;15435845]Share the link!! I've never seen the OEM lpfp go for that cheap.[/
http://www.ebay.com/itm/300671313277 I called them directly they are based out of San Diego. AJ was the person I talked to stated its 100% OEM VDO manufactured BMW lpfp as advertised with fuel level sending unit as pictured . |
02-12-2014, 11:11 PM | #8 | |
135
Rep 692
Depending on what's off, we should be able to diagnose what's wrong (Ethanol Content is too High, LPFP has started to die, etc) and hopefully diagnose.
Results > |
02-13-2014, 12:21 AM | #9 | ||
88
Rep 1,039
After you replace the pump run some logs and reset adaptations. When logging for me the initial surge of going wot I notice my fuel pressure drop to 66psi, but instantly recover to 78psi ( completely normal ). May car finally runs great again!!! |
02-13-2014, 08:08 AM | #10 | |
50
Rep 405
02-13-2014, 08:10 AM | #11 | |
50
Rep 405
How does your new LPFP do running E85 ? |
02-13-2014, 11:25 AM | #12 |
40
Rep 623
I was having very similar issues AFTER I installed my walbro 465lph E85 rated pump....But we switched out the pump with another walbro out of my buddies car, did the same thing... Put the stock LPFP back in, the car did the same thing...So I think im having a lot BIGGER issues than just my fueling and is at the dealership as we speak....I have a feeling its the rod bearings or something to do with the crankshaft. The last time I took my car in it they replaced the crankshaft sensor and I thought I would be good to go but the next day I took it back up to the dealership and has been there for the past month................IM BECOMING VERY IMPATIENT, ESPECIALLY AFTER I DEMODDED THE CAR, REMOVED BACKEND FLASH, REMOVED TUNE, and I have cam codes, vanos codes inlet and outlet, crankshaft codes, low boost mode engaged, and I think there is a couple more.. So I have no idea why its taking so long but im getting very angry since this is a SB and 99% of the techs/friends I have talked to, said its probably either the vanos or the rod bearings/journal bearings...im just waiting till I get that phone call and them saying everything is fixed, please come pick your car up because IM going thru "going fast" withdrawls haha
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
02-13-2014, 12:02 PM | #13 | |
135
Rep 692
You would probably start having issues if you tried running the E30 Map with a 35% or greater concentration. You could run the E30 Fuel Scalar on a Pump Gas Map, it just wouldn't be wise since you'd constantly have negative fuel trims (think of it like a sign of "over" fueling, so the DME is cutting back how much fuel it needs).
Results > |
02-13-2014, 12:20 PM | #14 | ||
Guest
Rep n/a
Drives:
02-13-2014, 03:37 PM | #15 | |
50
Rep 405
02-13-2014, 08:32 PM | #16 |
88
Rep 1,039
02-13-2014, 09:06 PM | #17 |
Stupid Idiot
134
Rep 827
Not to be argumentative, but Cobb recommends 30% ethanol (mixed with a minimum of 91 octane) to support the boost and timing the E30 Race Map commands. The fuel trims should be just fine with ~E25 in the tank, but I wouldn't be so sure about timing correction issues. Keep in mind we're in CA and have crappy ACN 91 octane we have to mix our E85 with.
02-13-2014, 09:14 PM | #18 | |
135
Rep 692
Results > |
02-14-2014, 09:18 AM | #19 | |
Stupid Idiot
134
Rep 827
Dropping fuel pressure doesn't have too much to do with the fuel scaler tables, though. Just wanted to make it clear that guys shouldn't be putting much less than 30% ethanol in with that race map from an octane/knock resistance standpoint.
02-14-2014, 10:36 AM | #21 |
Guest
Rep n/a
Drives:
[QUOTE=loweredram;15443839]Yeah, ordered one last night before the sale was over. A comparo would be much appreciated though...not going to be installing mine until spring time anyway.
