half engine light pass 4k rpm
02-11-2014, 01:38 AM | #1 |
Rep 65
When i try to get on it and the car gets pass 4000 rpm the half engine light shows up, but the car drives perfectly fine. When i restart the car the half engine light disappears and doesnt come back unless i go past 4k rpms When i try to read the codes no codes shows up about it except i do have 4 codes from the catless dps. Could that be why?
this is what the obd reader showed Misfire Monitor-OK Fuel System Mon-OK Comp Component-OK Catalyst Mon-OK Htd Catalyst-n/a Evap System Mon-OK Sec Air system-n/a A/C Refrig Mon-n/a Oxygen Sens Mon-OK Oxygen Sens Htr-ok EGR/VVT Sys Mon-n/a P0420-catalyst system efficincy below threshold bank 1 CONFIRMED P0430-catalyst stem efficiency below threshold bank 2 CONFIRMED P0420-catalyst system efficincy below threshold bank 1 PENDING P0430-catalyst system efficincy below threshold bank 1 PENDING but theres nothing about a misfire or boost leak. Last edited by randomhobo; 02-12-2014 at 02:03 PM.. Reason: updating |
02-11-2014, 01:21 PM | #7 |
562
Rep 3,625
Boost lead will definitely make it feel slower. When I had one the symptoms were similar to yours. Do a WOT pull and see if you get thrown back into your seat like you normally do.
02-12-2014, 02:03 PM | #10 |
291
Rep 2,898
02-12-2014, 04:01 PM | #13 | |
Rep 65
02-12-2014, 04:04 PM | #14 |
Rep 65
If they were swapped shouldnt the car be running like sh*t. It runs perfectly fine just when I get on it I get a half engine light. But no loss in power at all. I did what you told me and it seems I'm building boost just fine. Do y'all think the dps could be causing the half engine light?
02-12-2014, 06:09 PM | #15 |
Rep 36
Is your car leaking? Because I have a 07 AT with 73000 miles and had to replace the mechatronic sleeve and did the transmissions fluid as well but after that I am able to past 4k rpm without the half engine light. Where as before I had the same issue even when the car was fully warmed and everything.
04-27-2014, 10:27 AM | #18 |
e92javy
46
Rep 1,056
Old thread but, the same that happened to OP happened to me. It ended up being a cracked stock charge pipe.
Instagram- (javy_e92) 09 335i coupe / M package / Alpine White / Dinan Stage 2 / Alpina B3 Flash / Alufelgen SF71 / ST coils / Lux H8 / AFE Stage 2 intake / 6700k mtech HID / Performance trunk spoiler / Gloss black roof / CF interior wrap / PE Muffler Mod / ETS Charge pipe / Tial BOV / Cyba Quad Diffuser / Cyba Quad Black Chrome tips / Gloss black grills / AW reflectors / LED turn signals / Remote Key +
04-27-2014, 12:30 PM | #19 |
Rep 65
I still haven't gotten it fixed yet lol. But whenever I try to read the code there is no code. Did the same thing happen to you?
06-06-2014, 02:38 PM | #21 |
Rep 26
Please! Does anyone have a solution for this issue? OP, did you ever get this fixed? I just took my car to Autozone --- they couldn't find any fault codes. I also had my ODB2 (Bluetooth) w/ Torque application and it could find no fault codes either. What should I do? I don't want to have to take my car to the stealership, but I am quickly running out of options.
I am having the EXACT same problem as the OP and others on this thread. Any help would be appreciated! -Elo |
07-07-2014, 03:31 PM | #22 |
Rep 23
I still have this problem.
It seems to happen only once in a while under certain throttle positions in certain gears. It all started when I installed my JB4 in January of this year. Im FBO ( NO meth/ stock turbos) I did get an walbro 450 e85 compatible LPFP and changed the boost control solenoids. Good thing is my boost oscillation seems to have gone away, but I still got the yellow half engine at aound 4k rpm. (randomly) Im starting to think it may be a software issue , or my waste gate actuators arent operating like the should, or possibly a small leak in a vacuum hose. Ive got a new HPFP ill install while I walnut blast the intake. After that the only other thing I could think to do is upgrade to RB turbos... But thats a big investment. If I find anything Ill post more. |
