HELP! My turbo 335i feels turbo less!
02-10-2014, 05:18 PM | #1 |
12
Rep 53
I have a 2007 335i with the following mods:
VRSF 7" FMIC ER CP with TIAL BOV AR DPs JB4 G5 (diodes cut) Running map 1 (91 Octane) Last month, after I got my VRSF FMIC installed my car was really fast. Whenever I floor it, turbo kicks in and WHAM! I'm hauling ass. After two weeks, it seems like my turbo 335i is now turbo less. I had my main mechanic double check the entire turbo system and found nothing wrong. I did a factory reset on my JB4 G5, updated to the latest HEX file, changed my spark plugs since I'm at 63k and I have no codes at all on my dash. As of now, whenever I floor it, my car just makes this sound of air releasing underneath the hood. It's like the harder I floor it, the more air just escapes into the atmosphere. I'm so puzzled on why this is happening. Luckily I do have warranty and will have my SA check it out even with all my mods. My guess is my turbos have failed internally. |
02-10-2014, 05:35 PM | #5 | |
339
Rep 1,185
1) Check intercooler connections and check to make sure your intake isn't loose. Also check your vacuum lines around the turbo charger. 2) Do a log and post it up on the forums. If your fuel trims are maxed its possibly a fuel issue. If their not and your lpfp doenst dip then its a boost leak, intake leak, or possibly a wastegate issue. Once you post a log we can help you further.
2015 BMW M4 F83
2009 335i X-Drive | GC 2.0 Turbos (sold) 2009 335i e93 (Sold) 2007 Bmw X5 (Sold) |
02-10-2014, 06:28 PM | #6 |
36
Rep 1,176
Double check your charge pipe to make sure it didn't break. A friend of mine broke his on his 335i and it looked fine when just looking at it (checked at night and the lighting wasn't that great), but was clearly broken if you went to move it around or looked at it while the engine was revved.
335i Coupe, JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
02-10-2014, 06:48 PM | #8 |
12
Rep 53
Thank you everyone for the input. This car has been a love/hate relationship. I checked the charge pipe and it's not broken. All intercooler connections and couplers have been triple checked. I think my last resort is definitely turbo/waste gate related.
02-10-2014, 08:00 PM | #10 | |
200
Rep 2,799
thanks to MGallop |
02-10-2014, 08:23 PM | #11 | |
339
Rep 1,185
What tune are you running? with the fuel hijack it sounds like the open flash or the jb4/procede setup. You really should log the car's fuel trims, boost, LPFP, and and air/fuel ratio and even the waste gate duty cycle (although that i don't know someone else will). A log will help the diagnosis go from questionable to a precise area that we can point you to.
2015 BMW M4 F83
02-10-2014, 08:42 PM | #12 | |
12
Rep 53
Let me know if that works! Buster, I'm on Map 1 of the JB4. |
02-10-2014, 08:48 PM | #13 | |
339
Rep 1,185
From what i can see it looks like a big leak, or bad waste gates. Do you hear any rattle? I'd also check to make sure your wategate vacuum lines are intact and didn't break off or come off. That might cause a boost issue too. Btw, have you checked for codes with the JB4? If not check to see if their are any.
2015 BMW M4 F83
02-10-2014, 08:53 PM | #14 | |
12
Rep 53
As far as waste gate, I do hear a little rattle but not enough to convince me that it is that. I did see the vacuum lines that plug into a black canister but I didn't following it back towards the engine. |
02-10-2014, 08:55 PM | #15 | |
339
Rep 1,185
2015 BMW M4 F83
02-10-2014, 09:00 PM | #16 |
65
Rep 385
Check your bpv and vacuum lines. 5 psi sounds about right for a broken vac line. When my forge diverter valves would stick open, also 5psi was the magic number (sometimes 8, always too little).
02-10-2014, 09:08 PM | #17 |
12
Rep 53
02-10-2014, 11:52 PM | #18 |
65
Rep 385
Yep. By pass valves. There is a vacuum line running from each of the bpv's to a "y", which then feeds to a nipple of the intake manifold. There are a lot of threads about replacing vacuum lines, but that's the first place I'd look. The second place is under the engine cover, but there are a billion walk throughs for that one. Hit me up if you don't have luck and need help finding a good one.
Hearing the air is exactly what my forge bpv's would do when I first got them and they would stick. |
02-12-2014, 11:39 AM | #19 |
New Enthusiast & Photographer
8
Rep 105
Drives: 2009 E90 335i
My car is doing the exact same. Logs pulled show flat boost but level @ 5.
Checking vacuum lines, fmic lines and bypass. Let me know if you find something as well |
02-12-2014, 01:17 PM | #20 | |
200
Rep 2,799
thanks to MGallop |
02-12-2014, 06:00 PM | #22 | |
65
Rep 385
I opened/inspected/rebuilt/replaced and all was well for a couple of weeks. The problem then re-appeared. I re-did my rebuilt. Problem went away for a couple more weeks. Talked to Forge, they sent me rebuild kit with new pistons and it's been good for 6+ months, although just recently I've been missing quite a lot of boost at the top of my rpm range, so it's time for me to re-check. |
