Mod Plan Advice
02-10-2014, 03:46 PM | #2 |
456
Rep 6,478
Looks like a good plan to push stock turbos. Should clear 400whp without issue. I would consider replacing the charge pipe when you can, you’ll be pushing good boost with that setup and it comes on very quickly with the stock wheels. The stock chargepipe is hit or miss but if it breaks it’s not super fun to limp home with no boost and unfiltered air entering the combustion chamber.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
02-10-2014, 03:54 PM | #3 | |
Rep 51
02-10-2014, 09:57 PM | #5 |
2095
Rep 43,350
If you're running above stock boost levels it's safe to say that the stock CP is going to fail eventually. The stock DV's are also prone to failure/leaking when running more than 2-3 PSI above stock.
02-10-2014, 10:14 PM | #6 |
406
Rep 574
BT cable or OFT tablet for backend flash
Alpina flash if you're AT If you're pressed for $$ it's ok to skip the chargepipe/DV's for now. But I'd keep the fund for it open. |
02-10-2014, 10:25 PM | #7 | |
Rep 51
02-10-2014, 10:28 PM | #8 |
2095
Rep 43,350
You definitely shouldn't skip the DV's, the factory DV's will fail to hold above stock boost levels after a few thousand miles and the OEM CP will fail regardless after so many heat cycles.
It's a preventative mod more than a power mod. You don't want to inject plastic pieces into your motor when the CP breaks apart and leaves you stranded on the side of the road. |
02-10-2014, 10:30 PM | #9 | |
Rep 51
02-10-2014, 11:57 PM | #10 |
89
Rep 3,732
Drives: BMW S1000XR
+1 on CP (ER but other options) and DVs (Forge).
BMWCCA member |
02-11-2014, 08:40 AM | #11 |
2095
Rep 43,350
We sell an upgraded chargepipe with your option of HKS or Tial BOV (we recommend the Tial)
http://www.vr-speed.com/vrsf-chargep...i-n54-n55.html |
02-11-2014, 10:12 AM | #12 | |
Rep 51
02-11-2014, 11:23 AM | #13 |
77
Rep 2,114
VRSF's Charge Pipe as well as pretty much every other manufacturer will fit your car, Greg. I just ordered VRSF's CP with Tial BOV this weekend through Top Gear Solutions. Can't go wrong with it for the price.
E92 '08 335Xi 6AT - Cobb AP3 Tuned by MAC Autosport, Original Prototype Xi DOCRace 6266 Single Turbo Swap, VRSF CP w/Synapse BOV, VRSF 7" FMIC, BMS Cowl, H&R Coilovers, Renn Motorsport RS-51's, Stoptech Stage 2 Slotted, xHP Stage 3, Earl's Racing Oil Cooler, Turner Boost Gauge, M3 Lip Spoiler.
Standing Mile Record Holder for Xi over a mile high: 168.2MPH @ 5512'; The Colorado Mile hosted by The US Mile. |
02-11-2014, 11:25 AM | #14 | |
Rep 51
02-12-2014, 09:08 PM | #15 |
BimmerPost Supporting Vendor
24198
Rep 190,805
Add a CP and you have a pretty solid plan
02-12-2014, 09:28 PM | #16 |
Joint Chiefs of Staff
4918
Rep 115,980
I am a fan of Forge DVs, but the Tial BOV is great as well. There are a bunch of CP options on the market, with the most popular being ER. Whatever charge pipe you buy make sure it uses the stock C-Clip mount, and not a silicone coupler. The stock C-Clip mounting system is the best for holding boost and not popping off.
Mike |
02-12-2014, 11:59 PM | #17 |
135
Rep 692
You're going to need some flash tune to make the Walbro LPFP upgrade worthwhile... Whether you use COBB, the BB/BMS Backend, or OFT you'll need something to adjusting the Fueling Tables.
Results > |
02-13-2014, 12:01 AM | #18 | |
Rep 51
