ACS replica lip owners. Need your help.
11-08-2007, 08:45 PM | #1 |
37
Rep 405
Warmest greetings to all. I'm trying to finish up my ACS lip install but have run into a problem. I removed the silver bumper accent trim using the DIY provided here, but the black bars that held the silver trim in place also protrude out and prevent the lip from laying flush against the bottom of the bumper. Everything else (drilled holes in the bottom, snaps on tightly at the wheel wells) is perfect.
Interesting enough, there are grooves built into the inside of the center pillars to account for the accent trim holder, but not for the left and right areas. Pics are here: http://i151.photobucket.com/albums/s...l/IMG_0030.jpg http://i151.photobucket.com/albums/s...l/IMG_0029.jpg To those who have this lip, how is this dealt with on your car? to make it fit? did you create grooves by drilling them out of the lip? Something obvious I'm missing? Please advise, and thank you in advance. :-) |
11-08-2007, 08:54 PM | #2 |
Critical Care Anesthesiologist
481
Rep 8,828
Drives: SMB F83
dremmel out the black plastic bars?
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
11-08-2007, 08:59 PM | #3 |
37
Rep 405
certainly a possibility. would that be better than simply cutting the small wedges out of the lip? can those plastic grills be inexpensively replaced, should I remove the lip in a few years? |
11-08-2007, 10:01 PM | #4 |
112
Rep 2,589
I took out the front lower grills..
11-08-2007, 10:04 PM | #5 |
481
Rep 8,828
Drives: SMB F83
those grilles can be replaced
11-08-2007, 10:36 PM | #6 |
37
Rep 405
Did you have to take the bumper off to do that or is it more simple? I didn't see any DIY's on that.
Well that makes me feel better. A link or part number with price would go along way in making me feel better about cutting those pieces off. Thanks for the advise so far guys. |
11-08-2007, 10:55 PM | #7 | |
112
Rep 2,589
If you cut them then I guess you don't need to take off bumper |
11-09-2007, 05:31 AM | #9 |
481
Rep 8,828
Drives: SMB F83
realoem.com is your friend:
http://www.realoem.com/bmw/showparts...13&hg=51&fg=15 Looks like the 3 grilles are 10 bucks each
11-09-2007, 06:14 AM | #10 |
37
Rep 405
No, you are my friend. Real OEM is just confirmation. :-D
Thank you for that. I'd rather cut them out than try to take this bumper off. Especially with the risk of damaging my washer system. hitting it with my dremel now. Thank you, all. |
