2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions BMW F10 Passenger Carpets Wet Help!!!
      02-09-2014, 06:55 PM   #1
anthonyadf
anthonyadf's Avatar
United Kingdom
23
Drives: BMW F10 520d SE
Hi Guys,
I have seen several posts with regards to wet passenger side carpets, checking micro filters, water testing, etc.
After removing my seat and pulling up the carpet to dry it all out, I went to check the micro filter and noticed that there was another pipe next to it which had come off. Is this a drain pipe and what would people recommend to do to see if this is the cause?
I guess there could be a very small chance that I knocked this pipe when getting the carpet up?
Pictures attached!
Thanks in advance,
Ant
anthonyadf
      02-10-2014, 03:39 PM   #2
ghueser
37
Drives: 2014 M5
Hard to tell but that looks like the air conditioning Evaporator drain tube, which would likely be the culprit for the wet carpet. Does it look like it clips to anything to prevent it from coming off again?
      06-05-2015, 05:04 PM   #3
Oromero910
Drives: 2012 bmw 528i
was your problem that drain pipe????
      08-17-2021, 11:10 AM   #4
535inNYC
Drives: '14 M5, '18 GT3, '08 911 Turbo
zip tie?
5post
