2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY - Remove Chrome Trim Handle Strips F10
      02-06-2014, 04:09 PM   #1
MUNIK-FL
MUNIK-FL's Avatar
28
Drives: Nissan Titan XD
I wanted to plastidip my chrome handles black (to match the black line), but I could not spray on the the handle and peel back to reveal a crisp line. So I decided to remove them and paint them off the car.
AFTER:
Name:  After (Medium).JPG
NOTE: I also plastidipped the side marker lights
Here is what I did:
First, get a plastic pry tool (I used this one):
Name:  Removal Tool (Medium).jpeg
Carefully pry the front end of the chrome piece out:
Name:  Get front side out first (Medium).jpeg
NOTE: FRONT OF CAR IS TO THE LEFT
Then feed some dental floss through the gap and drag from front to back to unstick the double sided tape that holds the chrome trim piece to the handle.
Once the tape has been separated, you need to push the chrome trim forward (toward the front of the car) so that the rear of the chrome trim can clear its key way. Be careful to not snap the plastic fins trying to remove it.
Name:  Rear side slides out of key hole (Medium).jpeg
NOTE: REAR IS DOWN
This is what it looks like with the two different clips and the holes they go into:
Name:  Shown with mounting tape and the types of snap in connections at the front and rear (Medium).jpeg
NOTE: FRONT IS TO THE LEFT AND REAR IS TO THE RIGHT (PIC IS UPSIDE DOWN)
Next, use goo gone to remove the tape from both the handle and trim.
Paint the chrome as desired and install 3M double sided mounting tape to the trim.
Re-installing is easy enough: Peel back enough (1/2" or so) of the tape backing nearer the front (smaller clip) and fold over so that when it is installed, you can grab it. Slide the rear tab back into its key way and snap in the front clip. Grab the tab you made and peel from the front of the trim piece to the rear. Apply plenty of pressure to bond the two pieces together and you are done!
Name:  After (2) (Medium).JPG
Mine have been plastidipped for about a year now and it has not peeled at all, even though the car is washed about two to three times a week at a regular, non-touch free car wash.
2007 E92 335i / Montego Blue/Black - European Delivery - Retired
2013 F10 550i / Alpine White/Cinnamon - Retired
2014 F10 M5 / Singapore Gray/Sakhir Orange - Retired
2016 F15 X5 XDrive50i / Black/Black - Current
__________________________________________________
      02-08-2014, 12:43 AM   #2
omer
Drives: M8 GC
You should just vinyl them, would look much better.
      05-28-2014, 01:14 PM   #3
top6491
MSGT USMC (Ret)
Drives: 2012 AW F10 535i M-Sport
2012 BMW 535i  [0.00]
Nice job. I'm a believer in plasti-dip, dipping wheels, diffuser, etc. You can actually spray clearcoat over plasti-dip to give it a glossy and smooth to the touch feel. I did it on wheels and it turned out great. Then plasti-dip back ove the clearcoat to remove like normal plasti-dip, no problems.
      06-13-2014, 03:21 PM   #4
Julesandtrish
Julesandtrish's Avatar
27
Drives: 335d
2010 BMW 335D  [10.00]
Nice...... I was actually able to do mine without taking the trim pieces off. Just had to tape off everything really well. It was a while ago and I think I used 5 or 6 coats per door. Peeled right off just fine for me. Go figure. Yours looks great though!
Enjoy what you drive.
      05-02-2018, 01:56 PM   #5
PetePap
PetePap's Avatar
Drives: 2015 550i xDrive M Sport
Great thread! Which side do I need to pry first so that I do not crack anything? The side that faces the FRONT or BACK of the car?
5post
