Where to buy 335D thermostats- Euro Car Parts or BMW dealers
02-04-2014, 04:01 PM | #1 |
Rep 66
Hi,
I am looking to change both of the thermostats on my 335D this weekend. I was wondering are the one's that Euro Car Parts sell any good and if they are genuine OEM quality. The reason why I ask as there seems to be quiet a significant price difference between them. BMW Price Main Thermostat - part number 11517805811 £58.06 EGR Thermostat - Part number 11711787870 £44.65 Total Price £100.71 ECP Price Main Thermostat - Euro car parts link £34.56 EGR Thermostat - Euro car parts link £27.24 Total Price £61.80 ECP on ebay links http://www.ebay.co.uk/itm/OEM-Standa...item35cdaf66e0 http://www.ebay.co.uk/itm/OEM-Standa...item51b7140f21 Last edited by olivers; 02-04-2014 at 04:31 PM.. Reason: links not working |
02-04-2014, 04:35 PM | #2 |
Wheelbarrow Edition
60
Rep 1,608
The EGR thermostat i got from ECP had beru stamped on it (which is oem)
Then the bmw badge had been ground away. So was a genuine part in disguise. I also bought the main stat from ECP It works and my car hits 90 degree's so why not!! |
02-05-2014, 01:15 AM | #5 |
12
Rep 693
Are your prices from the dealer without discount?
Most dealers will give you 10% discount.
02-05-2014, 01:28 AM | #6 |
147
Rep 2,048
Those prices for stats from BMW do seem a tad bit high unless they have increased them in the past year. I think I paid £78 for both stats from BMW a year ago - try ringing another dealer for a price
I would personally pay a bit more and get the genuine stats from BMW. I have read stats from ECP are prone to fail (google search). for the time it takes to access the main stat you might as well use genuine as its a couple hours of labour plus coolant to re change Use genuine bmw coolant as well as it is not suppose to be mixed with other types unless you do a full flush diy to thermostat change, its for a 330d however it is the same/similar on the 335d - I did mine following this guide and it took me half a day as I was taking it slow - no doubt a garage can do in couple of hours http://www.e90post.com/forums/showthread.php?t=632656 |
02-05-2014, 02:10 AM | #7 |
Rep 54
I bought the more expensive item offered on the carparts4less site and they have been fine - also use the voucher code posted on the homepage to get more off.
This was after buying the one from ecp - and the main one failed. When I removed it 3 months later i found that the rubber internal seal had completely dislocated from its seating area causing the stat to be permanently open. |
02-05-2014, 02:36 AM | #9 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
LCI 330d only has a main thermostat, no EGR thermostat is fitted.
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
02-05-2014, 04:00 AM | #10 | |
Wheelbarrow Edition
60
Rep 1,608
So Bmw ones are prone to failure too My ECP one is working grand |
02-05-2014, 05:48 AM | #12 |
Rep 172
I got both from ECP and the EGR one was OEM with the BMW ground off due to licensing. The mainstat wasn''t an OEM part, even though it was the more expensive part listed by them. The quality of the plastic wasn't anywhere as nice as the part that came off.
I ran with it as it isn't a massive job to take it all off to change it again should it need changing. If it fails within a year then it will go back under warranty and I'll source a discounted genuine part instead. |
02-05-2014, 06:07 AM | #13 |
Beemer Heaven
462
Rep 2,941
All thermostats fail at some point, its just the nature of how they work. They should ideally be replaced every five years or so.
Don't forget that a BMW item will have a two year warranty with it.
Scott
02-05-2014, 06:46 PM | #14 |
56
Rep 623
Drives: F10 530d M Sport, E87 118d M
As previous poster has said - BMW parts are prone to failure on numerous fronts. ECP and Carpart4less are the same company. The latter sell at about 30% less than ECP without discount codes. The EGR thermostats are exactly the same whether you buy from BMW, ECP or CP4L. The main thermostat has a number of manufacturer sources. No particular manufacture has a proven record better than the alternatives.
F10 530d M Sport, September 2012 Individual Amazonite Silver, Oyster Dakota Leather, Auto, Nav Pro, Bluetooth + USB Devices, Expanded BMW Online, Comfort Seats, Sunroof, Sun Protection Glass Individual Satin Walnut Honey Brown Trim Interior Inside/Outside Mirror with folding and autodip, M Rear Spoiler
02-06-2014, 05:57 AM | #15 |
Rep 60
I Changed both of mine on my 330d originally from ECP however after a week or so I was struggling to get up to full temp again. Changed both to Gen BWM 3 month on still ok.
You can tell the main stat from ECP is a lot less quality when you compare it to the BMW. The EGR valve from euro is probs ok as they looks exactly the same except the ECP stat had the bmw badge rubbed off. All in all it cost me an extra £30 for gen BMW and IMO worth it HTH |
