DPF removal
02-02-2014, 01:03 PM | #1 |
E30 Obsessive
Rep 45
DPF removal
This may be a silly question but wel see. I do huge mileage and with it now being an MOT failure to have no DPF would it be worth my while removing it?
They do get blocked/knackered and theyr very expensive replace. Would it be sensible to have a delete pipe made to give me a bit extra go and then come MOT time I can put the DPF back in? I know there is controversy surrounding removal. What seems to be the general consensus on it these days?
E21 316i + E30 340i + E36 318TI Dakar
BMW I car sales exec [00=[][]=00] |
02-02-2014, 01:15 PM | #2 |
Beemer Heaven
462
Rep 2,941
Drives: BMW M4 Competition
Garage List 2018 BMW F82 M4 Comp [0.00]
2017 BMW F30 330d M ... [0.00] 2014 BMW F30 330d M ... [0.00] 2009 BMW E90 330d M ... [0.00] 2006 BMW E90 330d M ... [0.00] 2002 BMW E46 325i S ... [0.00] |
If your doing lots of miles and the DPF is giving no trouble then I'd leave it alone....
Scott
2018 BMW M4 Competition 2019 Mini Countryman Cooper S : 2008 Mini Cooper |
02-02-2014, 02:43 PM | #4 |
14
Rep 181
Drives: 330D M Sport
I'd leave it in place. I went through this recently with a partially blocked DPF, after weighing up the implications... MOT inspections...potential sell on issues... etc decided it's a hassle thing to maintain, but potentially cheaper and less hassle than if I removed it.
02-02-2014, 02:45 PM | #5 |
12
Rep 693
If it ain't broke, don't fix it
02-03-2014, 06:43 AM | #6 |
Rep 79
If you want a bit of extra oomph then i say go for it, i doubt you'll even need to refit it come MOT time but if you do it's not a hard job on the 4 cylinder diesels unlike the 6 cylinders. Hardest part was seperating the existing dpf from the mid section but once it's done once it shouldn't be too much of an issue in future. And as you say keeps your DPF in good condition.
HTH |
02-03-2014, 09:30 AM | #7 | |
E30 Obsessive
Rep 45
02-03-2014, 10:56 AM | #8 |
Rep 79
Yes you would still need to have it remapped to stop the engine trying to undertake the regen.
Yes it's not a dificult job to do on the 4 cylinders once the undertray is off theirs few bolts to undo which really which arent that hard to access either and then seperate the DPF from the mid which could be easy or it could be a pain vehicle dependant. Have a chat to Ecotune. They're based in Glasgow. Look out for a group buy on one of the forums you can get as much as 20% off one of their DPF delete kits. HTH |
02-03-2014, 12:56 PM | #9 |
53
Rep 1,272
Why not cut the DPF open, smash the insides out, weld in a straight pipe, then weld the cover back on the DPF so it "looks" standard.....not like their going to remove your exhaust to check it for MOT
Monte Carlo Blue M3 Comp |
02-03-2014, 05:03 PM | #10 | |
Beemer Heaven
462
Rep 2,941
Do you actually have a DPF problem?
Scott
02-04-2014, 02:53 AM | #12 |
Beemer Heaven
462
Rep 2,941
Because if it's left alone you don't need to touch it at all
Scott
02-04-2014, 03:07 AM | #13 |
Rep 79
Until it blocks at which point it could be mega bucks but each to their own
I wanted some more power too so as I was getting it remapped anyway I thought it would be rude not too.... For info at MOT time mine blew 0.03ppm the limits is 1.5ppm the machine couldn't even detect that the engine was being revved with the exhaust probe so they had to connect a cable to the battery terminals to detect the increase in RPM. HTH Last edited by E91-Gaz; 02-04-2014 at 02:48 PM.. |
