Carbon Fiber front lip loose
02-01-2014, 07:59 PM | #1 |
Rep 26
Hey Guys,
I have normally had great experiences with mod bargains, but they installed my lip and two days later one side is losing its adhesive. I'm in Santa Monica and don't want to drive all the way out to La Habra to have them fix it. Can anyone here point me to a good place or someone that knows how to fix it. I bought 3m double sided tape, but i'm not really doing a great job at fixing it. If you look at the picture below you can see the adhesive starting to slip on the left side of the picture. |
02-01-2014, 08:45 PM | #2 |
168
Rep 842
I just installed my 2nd front lip today (first one fell off on the freeway). I highly recommend ~1.5" bolts with washers and nylock nuts. You have to drill the bottom of your bumper (right side and left side). Run the bolt and washer up the hole you drilled and inside the bumper run the 2nd washer and nylock nut.
You don't have to remove your bumper. Just the under tray. Trust me, tape will not hold it up. Nor will self tapping screws.
02-02-2014, 12:45 PM | #5 |
168
Rep 842
I wouldn't do that, that's too permanent for me. If the lip partially rips off, it'll be difficult getting the remainder off the bumper. Plus it'll screw up your bumper.
At least with a few holes drilled in the bottom of your bumper (which no one can see), the lip is adjustable and removeable.
02-02-2014, 03:15 PM | #6 | |
Rep 26
If anyone knows someone in the LA area that can fix this for me that they can recommend I would very much appreciate it. It's just frustrating that I will now have to pay more money to get it fixed. |
02-02-2014, 03:38 PM | #7 | |
843
Rep 3,146
Bagged F90 M5
Gen 2 Raptor IG thatcarguypj |
02-02-2014, 08:04 PM | #8 |
257
Rep 934
It doesn't look like they did anything wrong per say from the way you described it. Using self taping screws on the bottom and tape up on the top that touches the bumper should typically do the trick. Not sure that any other shop would do anything differently. The only other way to do this would be to permanently epoxy or betalink the lip onto the bumper. Risk in doing that is if you hit something on the road, its very likely that both your lip and part of your bumper will come off. Either way, you should speak to them before posting negatively here on the forums.
02-04-2014, 12:35 AM | #10 |
965
Rep 5,032
Get the Super strong 3m double sided tape. When I installed my Performance rear spoiler by myself the first time around it was slightly off, so I opted to try pulling it back off, but it was on there so tightly I had to break out the heat gun and work it off slowly. Since putting it back on with a buddies help that thing is on there so well it does not even budge if I tug on it.
