Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > 320d (177) Tuning?
      11-07-2007, 04:23 AM   #1
Holjon
Holjon's Avatar
13
Drives: GT3 RS
320d (177) Tuning?
Does anyone know of a company currently chipping these engines?
Also, has anyone had it done and is it worthwhile?
Many thanks
      11-07-2007, 04:37 AM   #2
Bumps
Bumps's Avatar
United Kingdom
18
Drives: E92 320i M Sport
Welcome Holjon!
Though the 177 is a 'new engine', DMS mapped the 'old' 163 version up to 209bhp (www.dmsautomotive.com) - they're expensive but have excellent aftersales etc from what I understand. Believe Superchips do it and Chiptune also, no doubt amongst others. That's all I know, as I was investigating it for my 120d but never got round to it. DMS would have been my choice, as much for their thoroughness as for the fact that I live close by. A couple of the guys here have remaps on 320ds, so no doubt one of them will impart their wisdom. Also see this thread:
http://www.e90post.com/forums/showthread.php?t=94011
Let us know what you go for.
      11-07-2007, 11:17 AM   #3
Holjon
Holjon's Avatar
13
Drives: GT3 RS
Just spoke to DMS. At this time there is no work that can be done to chip the new diesel engined 320. Apparently the ECU is encrypted and so may never be able to alter the map. Shame.
      11-07-2007, 02:05 PM   #4
Bumps
Bumps's Avatar
United Kingdom
18
I asked DMS the same question about my 320i (yes Carlos I know the gains wouldn't have been worth it - before you start), and got the same answer. Because I knew that it might not be that lucrative for them to remap NA 2.0 petrols, I wondered if they just couldn't be bothered, but thought it unlikely. Sounds like there was a BMW conspiracy after all!! I think people remapping basically takes BM's profits away. They have a finely structured range, the prime example being 325d buyers get the same engine as 330d buyers effectively (though not exactly - but a remap can really close the gap), so they could buy a 325d and map it, and save a packet, and BMW lose out. See this thread
http://www.e90post.com/forums/showth...cult+remappers
      11-07-2007, 04:41 PM   #5
E92Fan
Moderator
E92Fan's Avatar
United Kingdom
322
Drives: .
Everyone's quite correct - the new ECUs in the latest-build cars have more advanced encryption on them so it's proving very difficult to remap the ECUs. You can install piggy-back modules instead, but that's not technically a remap.. As far as I know, Birds/Hartge UK are the only company who can get through the encryption, as they have links to a programming team in Germany who have the direct access to the ECU software...
      11-07-2007, 05:03 PM   #6
Holjon
Holjon's Avatar
13
Drives: GT3 RS
And they charge you for it!!! £1200 for a remap, and only 13hp gains..... not so attractive.
      11-07-2007, 05:20 PM   #7
E92Fan
Moderator
E92Fan's Avatar
United Kingdom
322
Drives: .
Yes, not the cheapest... don't know about the gains though - I have a feeling the PDF file on the website is wrong as I think it still refers to the old engine... not sure though so don't quote me!
      11-08-2007, 12:55 AM   #8
Bumps
Bumps's Avatar
United Kingdom
18
      11-08-2007, 07:54 AM   #9
330cdsport
Right Responsible
330cdsport's Avatar
United Kingdom
58
Drives: AW F21 M135i
I assume that a tuningbox should still work with the 320d (177). Should take it up to about 210.
Last: 330cd Sport - Silver Grey, 335d M Sport Coupe, F10 535d M Sport.
Current: AW F21 M135i, Coral Red, Pro Nav, Vis, HK, & Clunky Adaptive Suspension
Current: F15 X5 XDrive 40d M Sport - Space Grey, lots of toys.
      11-08-2007, 03:49 PM   #10
Cafe.Racer
Cafe.Racer's Avatar
United Kingdom
27
Drives: 320d Touring
I have a Steinbauer P-Box on my 163 320d - works very well. They're specific to specific models, but you could check with them, Steinbauer UK have been very helpful.
Phil
      11-15-2007, 02:50 PM   #11
Phantomwar
Phantomwar's Avatar
Norway
Drives: E92 M-Sport 2008
Anyone found out which Chip is the best for this engine ? Is it possible to use the same chip for the E92 320d, 177hp as the 120d,177hp ?
      11-16-2007, 12:44 PM   #12
CrimsonRedE93
CrimsonRedE93's Avatar
United Kingdom
108
Drives: Le Mans Blue E93 330d+
I was just reading the WDS on the 320i (thinks its N45 engine) and the S verion os the engine used for touring cars that outputs 275hp.
I guess the are probably not many parts that have not been changed though.
      11-16-2007, 06:39 PM   #13
E92Fan
Moderator
E92Fan's Avatar
United Kingdom
322
Drives: .
Yes, they're the same engine and gearbox combination. However depending on when your car was produced, the encryption levels on the ECU might be different, so one may be easier to remap than the other. The only sure way to tell is to give the VIN number to someone like DMS Automotive who can find out very quickly if it's high-level encryption or medium-level.
Incidentally, if it's high-level, very few places are managing to crack the code. Birds/Hartge is one, and the others as far as I am aware use external piggyback boxes.
      11-18-2007, 02:52 PM   #14
Cafe.Racer
Cafe.Racer's Avatar
United Kingdom
27
Hmm. I don't know, but while you might be right that, fundamentally, the engine is the same, there appears to be a lot more "gubbins" bolted onto it.
So, encryption aside, I'm not sure that a 177 could run a map from a 163. I very much doubt it.
Phil
      11-18-2007, 03:45 PM   #15
E92Fan
Moderator
E92Fan's Avatar
United Kingdom
322
Drives: .
a 177hp can NOT run the map from the 163hp as you say, but the 177hp engine in a 120d uses the same map as the 177hp engine in the 320d (which I think was the original question)
      11-18-2007, 04:16 PM   #16
Cafe.Racer
Cafe.Racer's Avatar
United Kingdom
27
Ah, I get yer...
Phil
      11-18-2007, 04:50 PM   #17
spanishooligan
Crazy red bimmer
spanishooligan's Avatar
Spain
105
Drives: 320d e90 japanrot
2006 E90 320d  [0.00]
has anyone heard of a tunit plug and play chip? i saw it on the net a few days ago and it seemed intresting. if you google it you will get their web
Sig by Nikki
Japanrot 320d
18x8'5 m6 replicas
COOL GAME---->http://spanishooligan.mybrute.com
      02-04-2008, 06:39 PM   #18
Phantomwar
Phantomwar's Avatar
Norway
Hi,
Has anybody in this forum tried this plug and play tuning chip for the 320D 177HP ?
http://www.chiptuningdirect.com/bmw/...0kw_cr_en.html
E92, M-Sport, Sapphire Black
      02-04-2008, 11:58 PM   #19
nagge
Swedish user
nagge's Avatar
Sweden
Drives: 06' E90 330dA
Hi,
Come on, you live in Norway, home to one of the best BMW tuners in the world, ESS Tuning
E90 330dA | SG | Remapped | Blacklines | Matte black kidney grill | M3 Steering wheel | Ümnitza Predator ICE LED Angel eyes | 18" M5 reps | ESS Tuning
      02-05-2008, 01:07 PM   #20
RDG 40
United Kingdom
Drives: E92 320d M sport
deisel tuning uk do a box for the 177hp
218hp and 420Nm
      02-05-2008, 05:05 PM   #21
Phantomwar
Phantomwar's Avatar
Norway
218hp and 420Nm
Is this a plug and play box where you can install the chip by yourself in 5 minutes without any ECU/Software update etc. ?
      02-05-2008, 05:33 PM   #22
dxb335d
The Tarmac Terrorist
dxb335d's Avatar
England
949
Drives: 997.2 GT3
you can always stick a tuning box on, they WILL work. Not as good as a re-map but never the less if no re-map is available this is the only option.
Carlos
997.2 GT3
Tags
177bhp, 320d, tuning
