BMW-specific codes
01-31-2014, 11:46 AM | #1 |
102
Rep 320
BMW-specific codes
I have the JBD CAN tool to read and clear codes, and I am getting some codes that I cannot find the meaning for, along with the occasional SERVICE ENGINE SOON light.
What do these codes mean? 496C 4D16 46A4 4600 |
01-31-2014, 01:46 PM | #2 |
411
Rep 3,049
Drives: 2009 BMW 335d
Those look very close to DPF related codes. How many clicks on your car?
01-31-2014, 07:52 PM | #3 |
102
Rep 320
46,000. I bought her last June with 30,000 on her. My one-way commute, which I do weekly, is 140 miles, so I'm clocking about 500 miles per week. I absolutely love this car--she's a real beast and I get 42 mpg on my commute!
02-01-2014, 08:25 AM | #4 |
Oil Burner
26
Rep 231
496C - P229F
Information saved in DDE Fault code 496C - P229F Fault text NOx sensor after DeNOx catalytic converter, plausibility NOx : Fault description Monitoring of NOx offset learning function at NOx sensor 2 (behind SCR). The error is recognized when the learned NOx offset value ppm rises above the limit value 20 ppm. Condition for fault identification Test condition: Continuous according to defined time grid when the offset test is enabled: - Enabled in application 0== 0. - The test is executed on a falling flank of . and when the following conditions are satisfied: - The absolute difference between the maximum ppm and minimum ppm NOx offset value is less than 2 ppm. - ppm is greater than 0 ppm. - The averaged offset value ppm lies within the monitoring window -30 ppm and 30 ppm. Voltage condition: Continuous according to defined time grid when the offset test is enabled: - Enabled in application 0== 0. - The test is executed on a falling flank of . and when the following conditions are satisfied: - The absolute difference between the maximum ppm and minimum ppm NOx offset value is less than 2 ppm. - ppm is greater than 0 ppm. - The averaged offset value ppm lies within the monitoring window -30 ppm and 30 ppm. Condition for fault memory entry Event debounced (1) Action in service Delete the DTC if the error frequency is 1. Respond to multiple occurences of this error by replacing the pre-SCR-cat NOx sensor. Fault effect and breakdown warning - Driver information Warning light: MIL Service instruction - © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions 4D16 - P20EE Information saved in DDE Fault code 4D16 - P20EE Fault text SCR system, efficiency: Efficiency too low Fault description Monitoring of NOx efficiency level (entire efficiency range). The monitoring function links SCR efficiency level monitoring in efficiency range 1 and efficiency range 2. The diagnostic trouble code is logged when an error is detected during monitoring of one of the two ranges. Condition for fault identification Test condition: The monitoring function is active when the conditions for SCR efficiency monitoring in efficiency range 1 and efficiency range 2 (according to temperature range) are satisfied. Voltage condition: The monitoring function is active when the conditions for SCR efficiency monitoring in efficiency range 1 and efficiency range 2 (according to temperature range) are satisfied. Condition for fault memory entry Event debounced (4) Action in service Refill SCR system tank with new fluid (urea quality) Use diagnostic system to test SCR converter. Check metering valve. Check NOx sensors. Inspect metering module for correct installation position and contamination. If results of all tests are OK: Replace SCR converter. Fault effect and breakdown warning - Driver information Warning light: MIL Service instruction - Urea quality (quality determination): Extract contents from tank and then refill. - NOx sensor before or behind SCR converter (indentified by corresponding diagnostic trouble code entry in ECU error memory) furnishing implausible data - Defective SCR converter, check with SCR converter system test - Coating on diesel particulate filter (indicated by DTC 4B91) - Check operation of metering valve. © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions 46A4 - P229F Information saved in DDE Fault code 46A4 - P229F Fault text DDE: NOx sensor after DeNOx cat., plausibility NOx: NOx signal offset too high at trailing throttle Fault description Monitoring of NOx signal offset value (NOx sensor 2 behind SCR). The diagnostic trouble code is logged when the average offset value exceeds the limit of 30 ppm. The offset is calculated by averaging the pressure-compensated signal with the constant 1. Condition for fault identification Test condition: The test routine is executed when the signal flank rises for a duration of Exh_tiNOxOfsTstVldNoCat2Ds. Within this time frame the absolute difference between the maximum and minimum NOx value must be less than 2 ppm. Once the diagnostic function is enabled the test routine is executed continuously in accordance with the defined process grid. Voltage condition: The test routine is executed when the signal flank rises for a duration of Exh_tiNOxOfsTstVldNoCat2Ds. Within this time frame the absolute difference between the maximum and minimum NOx value must be less than 2 ppm. Once the diagnostic function is enabled the test routine is executed continuously in accordance with the defined process grid. Condition for fault memory entry Event debounced (1) Action in service Use SCR converter system check to analyse NOx sensor 2 (behind SCR converter). ID0004 ID0005 Replace NOx sensor 2 (behind SCR converter). Fault effect and breakdown warning Proceed to the nearest BMW Service facility. Driver information Warning light: MIL Service instruction Perform metering diagnosis if indicated. © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions 4600 - P0087 Information saved in DDE Fault code 4600 - P0087 Fault text DDE: Rail-pressure plausibility pressure-controlled: Positive control deviation/rail pressure too low Fault description Monitoring for positive control deviation (rail pressure too low) while rail pressure is being regulated by rail-pressure control valve. The diagnostic trouble code is logged when the positive control deviation is greater than the limit defined by the operating point. The limit is calculated based on engine rpm and lies between 170 bar and 250 bar. Condition for fault identification Test condition: The test routine runs only when the following conditions are satisfied: - Rail pressure control with rail-pressure control valve, or rail pressure control with rail-pressure control valve and fuel-quantity control valve. - Monitoring is enabled. Voltage condition: The test routine runs only when the following conditions are satisfied: - Rail pressure control with rail-pressure control valve, or rail pressure control with rail-pressure control valve and fuel-quantity control valve. - Monitoring is enabled. Condition for fault memory entry Debounce (800 ms) Action in service Check the following potential problem sources: - Fuel presupply pressure (low-pressure delivery circuit) is too low (filter obstructed, leak in low-pressure circuit). - Rail-pressure sensor indicates incorrect value. - Leakage in high-pressure circuit. - Injector is sticking open. - Worn high-pressure pump. - Worn injector. - Leak in rail-pressure control valve. - Internal leakage in common rail system. - External leakage in common rail system. - Air in common rail system. Investigate potential problem sources, conduct rail-pressure control system test. Fault effect and breakdown warning Output governed. Proceed to the nearest BMW Service facility. Driver information Warning light: MIL_SVS Service instruction none © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions
'11 BMW 335d Sport
-JBD '07 Shelby GT500 -Not Stock |
02-02-2014, 02:24 PM | #6 |
102
Rep 320
Wow--UDAMAN. How can I get my hands on a complete listing of codes like that? Although my car seems to be running perfectly and gets great fuel economy, these codes are beginning to sound serious. I'd better schedule a dealer visit for this weekend. Thanks a million for the information.
02-02-2014, 02:57 PM | #7 |
Oil Burner
26
Rep 231
Well I have an AllData Pro account so I can look up all sorts of stuff.
I'm looking to make a Sticky where people can post their DTCs and I'll post the info like I did above.
'11 BMW 335d Sport
-JBD '07 Shelby GT500 -Not Stock Last edited by Brad335d; 02-02-2014 at 03:05 PM.. |
07-29-2015, 11:33 AM | #9 |
2011 Black 335d JBD
Rep 1
P0087 w/ JBD
Is this fuel rail pressure low (P0087) a side effect of running JBD at 100%?
Also, having difficulty clearing the code with the BT software and cable. Clear all codes doesn't seem to eliminate the check engine light. Any advice on either would be greatly appreciated. |
07-29-2015, 04:32 PM | #10 |
102
Rep 320
I believe it is. The only time I get this code is when I accelerate a little too aggressively before my engine has reached normal operating temperature. I clear the limp-mode and reduced power warning while driving, and use my handy dandy BMWhat and iPhone to clear the codes when I get to my destination.
I really like the BMWhat (now Carly) app. I have not used the JBD cable since I got it. |
06-23-2016, 03:35 PM | #11 |
My X5d tows my spec miata to the track.
74
Rep 1,254
Sorry to revive an old thread but this came up in my search for the meaning of a 436D code in my 2010 X5D. It comes back immediately upon startup. I can't figure out what it means anywhere. If anyone can help, I'd appreciate it.
Thanks. |
