ccc with USB support
01-31-2014, 10:36 AM | #1 |
355
Rep 1,846
So tbh I'm a bit confused I've read about Mulf 2 high svs, I have a 2007 e92 335d with professional sat nav and I think professional audio with bluetooth. I have a 6 cd changer and it isn't enough for all my music.
I want to add USB support purely to read mp3s from a USB stick and have basic control of next track etc. Is this possible to retrofit and what do I need??? What is a rough cost and I presume some coding will needed done? Cheers |
01-31-2014, 11:20 AM | #2 |
886
Rep 9,097
Mulf 2 high £80-100 (I have one).
Parts for 6fl + aux-in wiring = £100 Fitting and coding varies b/w £100-250.
F36 Xdrive for her - HUD, park assist, heated steering wheel, rear camera, Apple car play
F36 RWD for him - HK, M sports pack, GTS tail light, Apple car play |
01-31-2014, 11:22 AM | #3 |
8
Rep 219
check in the boot and see if you have a MULF2 unit under the rear cover (take it out) if you do you shoudl see a white USB port, if you have MULF2 then you can just run the cable + coding, if you just have TCU then you need MULF2 or CIC upgrade
02-08-2014, 03:01 PM | #6 | |
22
Rep 140
If it does not work might just need to active the option via coding. It works on my 2007 E92 Coupe (335D). Regards, Tich.
