2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack M235i Spare Tire or Not?
      01-27-2014, 04:25 PM   #1
jmcphillips1
jmcphillips1's Avatar
60
Drives: 2012 128 Coupe
It is common knowledge that the M235 will not come with run-flats and will instead come with the highly thought of Michelin Super Sports. This being the case, will the M235 then come with a full spare tire and wheel? If so, that is a lot of unnecessary weight that could be removed if you are taking it to the track for the day.
Current Daily Driver: 2015 X4 35i
Retired: 2012 128i Coupe M-Sport
Retired: 2009 X6 35i
Retired: 2003 X5 4.6is
Retired: 2006 330i Post September
      01-27-2014, 04:27 PM   #2
M.barnes
41
Drives: 123d
No spare I believe
      01-27-2014, 04:34 PM   #3
jrstech
jrstech's Avatar
78
Drives: '21 M550
It should come with a mobility kit (electric pump and tire goop canister) No spare.
'17 F80 (RET)
'14 F22 M235i (RET)
'11 E90 335i (RET)
'07 E92 335i (RET)
'89 E30 M3 (RET)
      01-27-2014, 04:35 PM   #4
jmcphillips1
60
well that would be good. As long as they give you something to help out in case of an emergency.
      01-27-2014, 04:40 PM   #5
kaputt
685
Drives: 128i 6MT - sold
Is the 228i coming with these tires as well? Perhaps just on the M Sport version?
      01-27-2014, 04:43 PM   #6
jmcphillips1
60
Only the M235 is getting the Super Sports...all others come with runflats
      01-27-2014, 04:45 PM   #7
Red Bread
Drives: Smog machines
M cars come with non RFT's and lifetime roadside assistance for flats. I assume the M235i will get the same.
      01-27-2014, 04:47 PM   #8
jmcphillips1
60
if that is the case then I will def get an electric pump to get me down the road if possible because waiting for roadside assistance can suck a dong sometimes.
      01-27-2014, 05:12 PM   #9
Red Bread
Mine had a compressor and a can of fix a flat, which my service guy threw away during PDI, saying it's more trouble than it's worth.
      01-27-2014, 05:18 PM   #10
bimmerfile
bimmerfile's Avatar
621
Drives: 2019 BMW X2 F39
Au contraire, mon ami. The M235i can be ordered with RFTs.
In fact, the M235i can be ordered with performance (e.g. summer) RFTs or All Season (A/S) RFTs as a N/C option.
Personally, I plan on ordering a M235i Cabrio xDrive with A/S RFTs in the fall.
2019 X2
      01-27-2014, 05:47 PM   #11
jmcphillips1
60
I think I'll stick with the Super Sports. Just too good of a set of tires.
      01-27-2014, 06:11 PM   #12
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
No way anyone will pass on the supersports for shitty RFT tires lol
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      01-27-2014, 08:14 PM   #13
SmallTownBoy
9
Drives: '14 M235i 6MT PSS BSM
I've ordered the M235i with March 8 ED. The standard wheel/tire is 2PG which is a performance RFT . There is no option for a non-RFT, unless they've changed the Canadian order guides since Dec 18.
IF you order the car with a/s tires, then you've just cut the top speed to about 135 mph from 155, since the a/s tires are not rated for the higher speed and they dial back the computer. I have ordered the summer performance tires and will also get winter tires and rims.
The Michelin PSS don't show up on the Canadian sheets. They may be a US-only option at the moment. I'm calling my CA tomorrow to make sure.
      01-27-2014, 08:23 PM   #14
jrstech
jrstech's Avatar
78
Drives: '21 M550
Not sure about the CDN order sheet but in the States you have to specify Run Flats or A/S tires at N/C option not to get the Michelin Super Sports. They are standard equipment.
'17 F80 (RET)
'14 F22 M235i (RET)
'11 E90 335i (RET)
'07 E92 335i (RET)
'89 E30 M3 (RET)
      01-27-2014, 10:19 PM   #15
SmallTownBoy
9
Just checked both guides and the standard wheel/tire in each is shown as 2PG, but they're slightly different: The US guide shows "mixed summer tires" with 18.5 x 7.5 rear. The Canadian guide shows "perf RFT" with 18 x 8.0 rear. The rest matches.
      04-07-2014, 02:49 PM   #16
Boneman
Boneman's Avatar
64
Drives: M235i alpine white on black
2014 m235i  [9.00]
2014 m235i  [0.00]
My 235 has no spare but does have the utility kit in the trunk.
      04-07-2014, 02:52 PM   #17
darkerosxx
37
Drives: '14 M235i
Also confirm no spare, but do have the mobility kit and a "tool kit" which includes a single screwdriver and the tow hook.
      04-07-2014, 03:22 PM   #18
Killramos
Killramos's Avatar
312
Drives: '19 M2 '21 X5
No spare on mine. (There is literally nowhere to put it)
Canadian car with PSS's. Came with the bmw mobility kit (aka compressor + fix a flat). Recommendation was just to use bmw assist if anything happens though.
      04-07-2014, 05:25 PM   #19
Delnari
Delnari's Avatar
Drives: 2014 MG F22 Auto
In the USA, we get the mobility kit and BMW Roadside Assistance that can be reached thru the SOS button on the overhead
Americans are too fat and lazy to be changing tires roadside. That is a another job created to help move our economy forward.
      04-19-2014, 07:31 PM   #20
Boneman
Boneman's Avatar
64
2014 m235i  [9.00]
2014 m235i  [0.00]
the road side assistance is excellent. When I cracked my wheel they were there in 20 min. Towed to BMW dealer and followed up with phone call to see how my experience was.
2addicts
