01-26-2014, 05:15 AM | #1 |
5697
Rep 3,225
Coding DAB Radio
Hello Guys,
I wonder if someone who codes and has DAB would mind looking at a few settings for me. I'm trying to see if I can code DAB to work on my car. In the NBT HU module, 3002 Audio_tuner there are three separate settings I can see for DAB. They are Radio_dab, Dab_standard and Radio_dab_varianten. Would someone please have a look at these in their car for me and tell the what the Werte value is for each. Thanks. |
01-26-2014, 06:28 PM | #6 |
5697
Rep 3,225
I have been told we get them as part of the HU in ours mate and I am not going to pull the thing apart just to confirm.
All I am asking for is the three werte values and I will see if it works, if it doesn't nothing is lost. Thanks anyway. |
01-27-2014, 03:43 AM | #7 | |
Supreme Being
1804
Rep 5,425
Anyway, werte blaues as requested: RADIO_DAB: Avtive Werte=01 DAB_STANDARD: dmb_audio Werte=02 RADIO_DAB_VARIANTEN: double_tuner_double_hw Werte=02 This is from my September build NBT with itouch
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
01-27-2014, 03:58 AM | #9 |
Supreme Being
1804
Rep 5,425
Anytime.
01-27-2014, 04:30 AM | #10 |
5697
Rep 3,225
I have just coded the car as per the same settings as Mark and unfortunately I didn't work.
Unfortunately it seems as though DAB is not in the HU as I was told? Thanks again Mark. |
01-27-2014, 04:42 AM | #11 |
Supreme Being
1804
Rep 5,425
Just a thought - have you VO coded DAB first?
If the DAB unit is in the HU after all but not activated, you'll need to have DAB added to the VO (DAB is 654 I believe).
01-27-2014, 05:05 AM | #12 |
5697
Rep 3,225
I tried to VO code that yesterday and it wouldn't take so I was just trying to see if I could just FDL code it. Thanks for the thought though.
01-27-2014, 05:32 PM | #13 |
40
Rep 458
Interesting. My post disappeared. Looks like you replied to yourself
If DAB was on your NBT as standard then I can't imagine BMW turning it off as standard. Can you add it as an option at order time? If you can, then it is possible it is already wired up. It is very, very easy to get to the back of the NBT to check and won't void any warranty. Takes me less than 5 minutes to pull the NBT out of my car and just requires a T20 to remove 8 screws. |
01-27-2014, 05:58 PM | #14 |
5697
Rep 3,225
Not concerned about warranty mate, just cant be shagged.
I've tried to VO code it in and it didn't work so the hardware mustn't be there. Yes, it is an option out here. I had it in my last one. |
01-27-2014, 06:14 PM | #15 |
40
Rep 458
Really does take no effort at all. If it's an option then I can't see them doing two different NBT units for one country so the hardware could be there.
The thread in the DIY section gives the instructions to remove it if you get interested. |
01-28-2014, 01:58 AM | #17 |
Supreme Being
1804
Rep 5,425
There's a very short thread here where someone has coded but it's not working potentially due to antenna wiring.
What I wondering is whether there is a different VO code for the NBT DAB - I can recheck my VO code for the numbers just in case it's different.
01-28-2014, 02:29 AM | #18 | |
40
Rep 458
http://www.f30post.com/forums/showth...=921688&page=7 When I removed 654 in my case, which wasn't on the radio, the VO coding then worked. What you should do is check the vin decoder for cars around you VIN going to the same country but with DAB and see what the option code is. Either that or just take a look at the back of the radio. |
01-28-2014, 03:58 AM | #19 | |
5697
Rep 3,225
I know it was 654 on my old car but that was with a CIC HU. |
01-28-2014, 10:38 AM | #20 |
Supreme Being
1804
Rep 5,425
Hmmm, not great news as I do have 654 in my FA. I've sent you a PM with a link to my email address - drop me a message and I'll send you my FA for you to compare with...
01-15-2017, 12:08 PM | #22 |
27
Rep 114
Sorry to drag this up again but i have been reading the forum for a while and decided it was time to attempt a retrofit.
I ended up buying the wrong HU first time, it was the cic professional with 8.8" screen and i didn't have a comm box so found i couldn't use it. i decided to buy the hu_Entrynav as i found one going cheap and it had dab which i wanted. the issue i have nis that i can't get the dab working, i changed the modulator to one which had dab output and wired to front of car. i did the vo coding and it just shows no signal. Have i missed anything out. |
