Service Engine Soon
01-24-2014, 06:49 PM | #1 |
Rep 19
Service Engine Soon
On the way home today had the light come on. Checked the codes and the following were logged.
P205B P3EED C0D32 I found some info on the first, but can not find anything on the other two. |
01-24-2014, 07:29 PM | #2 |
411
Rep 3,049
Drives: 2009 BMW 335d
Are you running an engine tune?
01-24-2014, 07:36 PM | #4 |
411
Rep 3,049
01-26-2014, 05:21 PM | #8 |
Oil Burner
26
Rep 231
OK so code one I CANNOT find a P205B but I CAN find a P20B5 which has 3 sub codes which can be further diagnosed with an OEM capable scan tool. I will post all 3 sub codes for you. Your scanner in only reading the generic P20B5 code and not the manufacturer specific code of i.e. 4601, 49E2, etc. The code P3EED and COD32 DO NOT correspond to any code I have listed in my AllDataPro system. If you are using a generic scan tool which I suspect you are it is most likely generating an ambiguous code that doesn't apply to the car.
1) 4601 - P20B5 Information saved in DDE Fault code 4601 - P20B5 Fault text DDE: Reducing agent, output of delivery module heater too low: Open circuit, heater circuit Fault description The error is recognized when no lead value stroke has been recognized after a specific period of time, meaning that the lead value remains below the threshold 0 1/Ohm. Condition for fault identification Test condition: A check for this error runs once per heating cycle. Voltage condition: A check for this error runs once per heating cycle. Condition for fault memory entry Event debounced (1) Action in service Check resistance of delivery module heater unit. Replace delivery module. Fault effect and breakdown warning - Driver information Warning light: MIL Service instruction Delivery module heating unit resistance: 2.9 - 5.5 ohms © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions 2)49E2 - P20B5 Information saved in DDE Fault code 49E2 - P20B5 Fault text DDE: Heating, SCR system, power peaks: maximum heat output too high Fault description Monitoring peak power in reduction agent pressure line heater. A short circuit is recognized when the peak heater output is above a limit value defined based on operating point and the peak power test has been completed. The peak power test is terminated when one of the following conditions is met: - An activation signal has been transmitted to the heater for at least 10000 ms. - When the peak power test has been recognized as terminated based on the shift in the heater's power. Condition for fault identification Test condition: The error check runs once the peak power test has been completed. Voltage condition: The error check runs once the peak power test has been completed. Condition for fault memory entry Event debounced (1) Action in service Check resistance of heater elements. Check heater wires for short circuits to ground. Fault effect and breakdown warning - Driver information Warning light: MIL Service instruction none © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions 3) 4C72 - P20B5 Information saved in DDE Fault code 4C72 - P20B5 Fault text DDE: Reducing-agent pressure-line heating: Short circuit, heater circuit Fault description Monitoring of reduction agent pressure line heating. The diagnostic trouble code is logged when the measured current draw from the deactivated heater exceeds the limit value 150 uA. Condition for fault identification Test condition: The error check runs continuously when the urea tank heater is deactivated. Voltage condition: The error check runs continuously when the urea tank heater is deactivated. Condition for fault memory entry Debounce (15000 ms) Action in service Check the control wire and the diagnostic wire. If wiring and plug connections are OK: Check plug connections for moisture. Use diagnostic system to test heating systems. Replace power switch. Fault effect and breakdown warning - Driver information Warning light: MIL Service instruction The power switch transmits an activation signal to all heaters. The first heater circuit is for the active tank heater, the second heater circuit is for the delivery module and the metering line. The control wire should not be in contact with ground or B+ when the DDE and power switch are unplugged. © 2014 ALLDATA LLC. All rights reserved. Terms and Conditions
'11 BMW 335d Sport
-JBD '07 Shelby GT500 -Not Stock Last edited by Brad335d; 01-26-2014 at 05:26 PM.. |
