Antifreeze / Engine Coolant never checked?
01-23-2014, 01:20 AM | #1 |
86
Rep 313
It's occurred to me that I can't remember when this is ever checked? There's no warning on the dash / iDrive and the Condition Based Service doesn't include this. Adding screenwash is a piece of cake and checking / replacing engine oil / brake fluid is done by BMW Service as part of CBS. ?
01-23-2014, 04:44 AM | #2 |
290
Rep 2,598
Ummm, you should check it! It's normally done as part of a service - or a visual inspection at the very least - or they say it's needs to be done. Not sure on the frequency of replacement though.
01-23-2014, 06:24 AM | #4 |
86
Rep 313
I have 9 maintenance items listed: MOT, MOT emissions, vehicle check, microfilter, engine oil, brake fluid, spark plugs, front brake pads, rear brake pads.
No engine coolant / antifreeze, battery state, screenwash (probably not as important!). Not sure if power steering fluid and clutch / automatic transmission fluid is required too? |
01-23-2014, 06:37 AM | #5 |
28
Rep 405
I'm not 100% certain, but I think coolant is filled for life. I guess that means it's probably a good idea to change after the warranty period. However, if you've had your water pump go and dump all the coolant you've already had a partial change. Just pick up a hydrometer and check a couple of times a year to make sure it's the correct concentration.
01-23-2014, 06:56 AM | #6 | |
46
Rep 891
http://bioengr.ag.utk.edu/Extension/...es/engcool.htm
01-23-2014, 10:28 AM | #8 |
147
Rep 2,048
I just got into the habit weekly check oil/screenwash/coolant/tyre pressure and ps fluid. I try to avoid relying on warnings electronic sensors because sometimes it might be too late and damaged caused
01-24-2014, 07:13 AM | #9 | |
Rep 40
The anti-freeze concentration should be checked as part of the routine service schedule, though. |
01-24-2014, 12:57 PM | #10 |
435
Rep 686
Drives: 06 330xi (TRADED IN)
I don't see any signs of leak, but I do have the level lower from time to time (not "low coolant indicator" low but just a slight variance to add 1/2 a cup of distilled water every 3 months low). Blue coolant, 06 330xi, 73K miles.
01-25-2014, 09:27 AM | #12 |
400
Rep 5,623
Mike Miller says:
Engine Coolant: Every 2 years Power Steering Fluid: Every 30k miles Manual Gearbox Oil: Every 30k miles ATF: Every 60k miles Diff Oil: Every 30k miles Brake Fluid: Every year |
01-25-2014, 11:30 AM | #13 | |
616
Rep 3,194
Drives: E92 325i MSport Coupe
What people (and BMW) overlook about coolant is that it's not just about preventing freezing, but coolant additives inhibit internal corrosion of the alloy passageways inside the block and head. These additives will deteriorate over time so, as usual, the BMW 'lifetime fill' mantra is bollocks.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
01-26-2014, 12:21 PM | #14 | |
1545
Rep 8,970
01-26-2014, 12:26 PM | #15 | |
Wheelbarrow Edition
60
Rep 1,608
Never in carnation is brake fluid yearly, its every 2 years Gearbox and power steering fluid are for the life of the vehicle (although it wouldnt hurt to refresh at 100k miles imo) Also BMW coolant is a bluey/green and apparently its a 15 year product Last edited by Jase 320d; 01-26-2014 at 01:00 PM.. |
01-27-2014, 04:59 PM | #17 | |
Rep 40
01-28-2014, 03:14 AM | #18 | |
46
Rep 891
the only coolant that is for any longer than 5 years is the Red/Orange stuff (like VAG G13) other colours of coolant have much shorter lifespans. brake fluid depends on the type of fluid used, and how hard its used, 1 yearly for a performance car is not exactly extreme. for a sedate rep mobile, 2 years will be sufficient. |
01-28-2014, 06:56 AM | #21 |
Wheelbarrow Edition
60
Rep 1,608
Internet scare moungerer who prays on insecure owners who think their cars are ticking time bombs due to reading internet threads
Then makes money from them by changing parts un-necessarily I read on another thread he recommends radiator replacement at 60k miles Its a very lucrative business |
01-29-2014, 08:11 AM | #22 | |
400
Rep 5,623
A few questions. Have you actually read his document, or just rely on what people have said what he recommends on the internet? I have the latest copy if you're interested. He doesn't sell anything. He gives all his information for free. What he recommends isnt some magic Mike Miller therapy. Its actually very similar to the old school BMW maintenance schedule, i.e Inspection I, Inspection II. So infact its NOT mike millers schedule (most people say that for ease), its just the old fashioned BMW way, before the free maintainence was introduced. For eg, oil changes. New BMW say ~18k, Old School BMW (mike miller) is 7.5k-10k. BMW recently changed the interval to 10k, what does that tell you. Also there is no such thing as lifetime. For anyone who is still unsure, just read his document and then make your own decision. No need to read internet threads about it, you can come to a conclusion yourself by reading his document. By the way, following mike millers suggestion is only recommended if you're keeping your car past 100k miles. If not then there's no need. He himself says this, for anyone who hasn't actually read his document. Last edited by mob17; 01-29-2014 at 08:17 AM.. |
